Technical Pinion Angle & Moving rear end Back
Discussion in 'Traditional Hot Rods' started by HuskerNation, Feb 5, 2024.
  1. HuskerNation
    HuskerNation
    My coupe’s wb is 122” from the factory but with the lowering blocks it has moved the rear end forward approximately 1.25”, which then causes the driveshaft to hit the yoke at the back of the trans. (thanks previous owner)
    So I need to cut the blocks to move the rear end backwards. I also need to shorten the lowering blocks by around 1.5-2” in height as they are just too large.
    If I do a cut of equal angle & amount on top & bottom of the lowering blocks, I believe it should move the rear end backwards, hopefully not change the pinion angle. Does this sound correct? Similar to the red lines below:
    Ned Ludd likes this.
  2. **** that’s a lot of block
  3. HuskerNation
    HuskerNation
    The stance is killer looking but it’s just too low.
  4. too low?
    **** no.
    Just a lot of block
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wasn’t this issue talked about a year or so back?
  6. mad mikey
    mad mikey
    Time to dis- ***emble, evaluation, RE-DO !
    427 sleeper and Unkl Ian like this.
  7. HuskerNation
    HuskerNation
    Probably was, I needed to re-confirm my thoughts before I open up the can of worms. I’m finally ready to start in on it now!
  8. seb fontana
    seb fontana
    from ct
    :eek::eek::eek::eek: Them rear springs are probably crying.. I would remove blocks and go from from there.
  9. There used to be Pinion angle wedges as they was called with different degrees.
    But thats a LOT of block !
    427 sleeper and SS327 like this.
  10. 6sally6
    6sally6
    MAN !! That's a buncha block .........
    6sally6
  11. DDDenny
    Check please!
  12. bobscogin
    bobscogin
    Good opportunity to clean up that scrub line issue, too.
    Black_Sheep and Unkl Ian like this.
  13. Post a pic of the spring hangers.
    Could be possible to shorten them and use less block
    Unkl Ian and Truckdoctor Andy like this.
  14. gary macdonald
    gary macdonald
    Too much block . You can always redrill the bottom block centering hole to move the diff. Back some . If you remove a block you’ll see a hole which corresponds to the spring retention bolt . Redrill it and move it exactly where you want .
    RICH B, lostone, SS327 and 1 other person like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ But is it a solid block???
    2OLD2FAST likes this.
  16. HuskerNation
    HuskerNation
    It looks to be one block, but fully solid I don’t know. With my luck I’d cut it only to find it hollow.
    vtx1800 likes this.
  17. Kerrynzl
    Kerrynzl
    Leaf Link it, and add override bars to handle brake torque
    As it sits with those blocks any acceleration "thrust" or brake torque will cause the driveshaft yoke to "Liberace" the transmission tailhousing.
    Adjustable upper override bars can alter pinion angle etc and multiple holes can be drilled to adjust ride height.
    This is from the Chrysler bible
    gary macdonald, SS327 and GuyW like this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Truckdoctor Andy likes this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    But you really need to rework things as mentioned. Your scrub line is BAD!!! IMG_2440.jpeg
  20. fastcar1953
    fastcar1953
    Also you don't have to cut blocks on both sides or at a angle. Just cut one of them in half and save the other for a doorstop. :D:D
    427 sleeper likes this.
  21. jimmy six
    jimmy six
    I’ve used 4” solid blocks to lower our 40 Chev for Bonneville. It has a Pontiac rear and stock leaf springs. I put in a front leaf spring wedge for caster alignment to correct the lean. With the wedge I used I needed a longer top on the “pin” bolt that held the spring together. I made that. It was the easiest thing I could think of. I needed an additional wedge under the spring/shock mount in the opposite direction to keep the u-bolts inline.
    HuskerNation likes this.
  22. twenty8
    twenty8
    I was going to mention the scrub line way back at the start, but I decided not to. It always seems to end up in a stupid discussion because peope don't really understand it.........:rolleyes:
  23. flynbrian48
    flynbrian48
    That's scary. How about bags and truck bars with a Panard bar. You'd solve a bunch of things wrong with that current set up. Yikes.
  24. theHIGHLANDER
    theHIGHLANDER
    That getup wouldn't last a month in Wayne County, MI.
    flynbrian48, Bearcat_V8 and Algoma56 like this.
  25. rusty1
    rusty1
    as above suggestions apply, how would you ever change a rear wheel?
  26. 1971BB427
    1971BB427
    from Oregon
    Blocks don't need to be altered, you can just drill a new alignment hole in the axle perch to change wheelbase. Wont solve scrub line issues, or eliminate that thick block though.
  27. Unkl Ian
    Unkl Ian
    Could shorten the driveshaft ?
  28. lostone
    lostone
    from kansas
    I'd just remove the blocks, put it back together and start over.
    Start with a fresh slate, see if you have room to shorten shackles, even an inch would help.
    Then build blocks if you need to, I'd build my own blocks, then you can put the holes where you want them, build the pinion angle into them etc....
  29. 19Fordy
    19Fordy
    Make some "practice" blocks out of wood and try them before you start cutting your metal blocks.
  30. chickenridgerods
    chickenridgerods
    from DSM, IA
    Ditch the blocks. Tweak the shackles and reverse the main spring eyes. Evaluate from there if it needs something more to get it down to where it looks good.
