pinion angle shims
Discussion in 'The Hokey Ass Message Board' started by riverrat, Mar 9, 2010.
  1. riverrat
    riverrat
    does anyone make 2 inch wide pinion angle shims?
    riverrat
  2. ELpolacko
    ELpolacko
    Check your 4X4 supply
  3. Joe H
    Joe H
    Check with NAPA, they sell combination shims that are 2" wide and varies degrees of angle.
    Check your local store for part # 704-1161, 1163, 1165, 1168
    (2" wide, 1,2,3,5 degree)
    Joe
  4. 4woody
    4woody
    Are you sure on those numbers?
    Napa online doesn't recognize them.
  5. gimpyshotrods
    gimpyshotrods
    Search on "caster adjusting wedge".
    The online part numbers are different now, since the last site "upgrade".
  6. I just bought a set of 2" wide 4 degree wedges of Fleabay cheap.
  7. chevyfordman
    chevyfordman
    speedway motors in nebraska
  8. Mr48chev
    No need to do Ebay or Speedway. Just walk into the local NAPA as 4woody said and tell them what you are after and take the numbers he provided along.
    You need to figure out how much angle change you need first though.
    As someone else said, they are standard fare at most 4X4 shops.
    Not to pick on FNG's but there are other places that sell parts for our cars besides Speedway motors.
