Technical Pinion damage - usable or not
Discussion in 'Traditional Hot Rods' started by V8-m, Oct 26, 2024.
  1. V8-m
    V8-m
    from Alaska
    I believe you but in Europe you can't buy even 1/3 of the rear end for that price:D
    Deuces, Sharpone and chryslerfan55 like this.
  2. dumprat
    dumprat
    from b.c.
    Those gears are junk.
    Those chunks are from stress cracks. Subsurface. The rear won’t last very long and will eat more bits off the gears and run them through your new bearings.
    Find another set of old gears. They are not uncommon. Should be able to find one, even in Alaska.
    V8-m likes this.
  3. Back in the '50's and '60's there were hundreds of old Fords on the road with gears that looked like that.
    Sharpone likes this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    And don't call me Shirley.
  5. Wanderlust
    Wanderlust
    Guess it all depends on your comfort level, definitely I would change the bearings but the ring and pinion are just fine for a vehicle that isn’t heavy or being raced. I guarantee bout half of you guys would **** your pants or puke a little your mouth if you saw what I run, trans and diff. The t85 makes some noise, it’s the best bits of 4 ******s and just plain worn out but I’ve put 25000 miles on it, much the same for the 9 “ diff made up from 3. Myself I value being able to keep most of my money in my pocket, I’ve no interest in trying to impress the ****wits at the local parking lot showin ****, been there done that. With the seemly total lack of quality parts these days I’ll just keep cobbling old **** together and drive it!
  6. Mr48chev
    This, I'd carefully dress those spots to get them just smooth.
    Deuces, Sharpone and mad mikey like this.
  7. AULIZ
    AULIZ
    Bearings not look very bad. I didnt see any rost. Old oil which is less or more look like rost.
    Need to see bearing races. Race shows if there is wear surface.
    If use old bearings, not use so much preload.
    With new, can have little more preload. After small drive should be OK.
    You feel preload (diff bearings) when put together. pinion must turn easily (when old bearings used) aso
    I would wash all first. Pinion bearings are most important check and maybe change (double tappered roller bearing front side of pinion + rear suport cylinderical roller bearing),.... but all need to wash first.
    First right preload with gaskets and after that You more gaskets from side to another to get right backlash.
    Im not sure which is right one. Racing rearaxles I use 15/100mm - 17/100mm. Old ford rear axles approx 0,2mm (20/100mm). Maybe its OK. Its ok when it feels good.
    Deuces, dmar836, V8-m and 1 other person like this.
  8. Deuce Lover
    Deuce Lover
    Motive is the gear sets you were asking about. Made in Italy ,yes.I have seen some more pitted than yours that guys use without a problem. Motive gear sets are mainly sold thru vendors. V8 Ford sales sells the pinion bearings and double cone.They say Timken but could be off shore made. What is your current gear set ratio? 9-34,9-37 ? Where are you in Europe? I am in France and maybe can help.Click on my user ID ,send me a PM and we can talk if you want.
    Here
    https://www.ebay.com/itm/264396144904
    Sharpone and V8-m like this.
  9. V8-m
    V8-m
    from Alaska
    My gear ratio is 9:34 well i would like new gears or used but better conditions than those pictured abowe. Wondering if i could buy those gears directly from manufacturer.
  10. 1952henry
    1952henry
    I think you have some numbers out of order
  11. 57 Fargo
    57 Fargo
    I’m ***uming he means 9-34 which would be a 3.78:1
    427 sleeper, Deuces, Nominal and 2 others like this.
  12. alanp561
    alanp561
    Sawdust is good too. Worked for several used car lots for years;)
  13. V8-m
    V8-m
    from Alaska
    Yes 3.78
    Deuces and Sharpone like this.
  14. In Australia we called those used car lots " Fly By Nighters "
    Deuces, alanp561 and Sharpone like this.
  15. Okie Pete
    Okie Pete
    The pits carry more oil and improve lubrication .
  16. That's like new, use it as is.
    Deuces likes this.
  17. Doublepumper
    Doublepumper
    from OR-WA, USA
    I've had a couple rear ends I blew the spider and axle gears in. After replacing the gears, they kept right on keeping on, just fine....with dinged up ring and pinion.
    Desoto291Hemi, Deuces and Sharpone like this.
  18. GlassThamesDoug
    GlassThamesDoug
    Funny I was thinking of sawdust while drinking a pinch of Baileys Irish Creme.
    I would think early Ford ring and pinions are lapped, and matched sets like 50s-current. If they are, you should not share pinions and ring gears with non paired parts.
    V8-m, Deuces and Sharpone like this.
  19. V8-m
    V8-m
    from Alaska
    Hello gentlemen,
    I bought a new ring and pinion set, used but in very good condition ( original Ford ). I couldn't bear the thought of damaged gears spinning in my freshly overhauled axle. Peace of mind comes first.
    Thank you all for your helpful suggestions.
    X-cpe, Baumi, jaracer and 6 others like this.
  20. Rocky
    Rocky
    Classified Editor
    Good onya.
    V8-m and Sharpone like this.
