Hot Rods Pinion mounted emergency brake
Discussion in 'The Hokey Ass Message Board' started by limp, Dec 9, 2015.
  1. limp
    limp
    Was doing a bit of brain storming for my current project and was wondering if anyone has ever run a pinion mounted emergency brake on an open driveline banjo rear end? Would be nice to not have the cables going to the drums.
    41 C28 likes this.
  2. 55willys
    55willys
    Why not run a driveshaft brake on the trans?
    VANDENPLAS likes this.
  3. gimpyshotrods
    gimpyshotrods
    I have put a few on the transfer cases of 4x4 rigs, and on the pinion of Deuce axles. Either way, they work fine.
    In each case, the stuff I used came from here: http://www.tsmmfg.com/driveshaftparkin.html
    I made the brackets. Not complicated stuff.
  4. 55willys
    55willys
  5. gimpyshotrods
    gimpyshotrods
  6. limp
    limp
    That might just work for me.....thanks
  7. gimpyshotrods
    gimpyshotrods
  8. 19Eddy30
    19Eddy30
    from VA
    I have a Question , are you useing it as a parking brake or in case you lose Your Brakes?
  9. Ned Ludd
    Ned Ludd
    Either way you have braking force multiplied by the final drive ratio, so you can do the job with a smaller brake. You also have differential action on the brake, which may be either an advantage or a disadvantage, depending on the cir***stances. Presumably any slip-limiting device would work on the brake, too.
  10. butch27
    butch27
    I have one from TSM on my bucket. Nice piece and great guy to deal with. We figured out that he one for a sprint car is the same as a banjo rear end.
  11. woodiewagon46
    woodiewagon46
    from New York
    Speedway catalog #501, page 50 part no. 715-3250, Pinion Mounted E-Brake. This one is for a 9" Ford but might be adaptable.
  12. aaggie
    aaggie
    If you are using a GM TH400 it is easy to get the trans output shaft setup they put on motor homes. It is all bolt on.
  13. limp
    limp
    Going to be using as parking brake.
  14. Hi-Flying
    Hi-Flying
    I have a kit that I won at a car show, it has everything but the handle I would sell at a bargin
  15. seb fontana
    seb fontana
    from ct
  16. Do you still have the kit for the pinion that you won at a car show or pics.
    my e- mail is samoht1926@yahoo.com.
    I’m trying to get one for a 8.8 rear out of a crown Vic.
  17. 54vicky
    54vicky
    I would hope you are not holding your breath.look at date on post better to try a PM
  18. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Thomas, I think he still has it. I will tell Hi-Flying to take a look at this thread. Sam
  19. Do you still have your e-brake kit that you won.
    I reached out to you last year but never saw a response. my personal e-mail address is
    Samoht1926@yahoo.com
  20. Thankyou. Would you please reach out to high flying and see if he still has his pinion e-brake kit?
    I just never saw a response
