Technical pinon angle advice
Discussion in 'The Hokey Ass Message Board' started by c/h, Aug 19, 2023.
  1. c/h
    c/h
    from iowa
    working on mt t want it low. Have center of pinon at 14" on center section. trans (350 turbo) at 10 inches so i need to raise my drive line up good 4 1/2, correct?
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Huh? Pinion angle should be equal & opposite of drive line angle ,working angles of u-joints should be within 1-3° .
  3. BJR
    BJR
    Pinion angle is measured in degrees, not inches. Do a search, lots of info on driveline angles here
  4. 57 Fargo
    57 Fargo
    However if the angles are correct the driveline doesn’t care that it’s angled down towards the transmission.
    @gimpyshotrods, you called it!:)
  5. Bandit Billy
    Bandit Billy
    I think he is measuring from the garage floor up to the pinion? If I am correct, the 4 1/2 inches sounds like it would get you close but it is not an accurate method or a correct one for that matter.
    I downloaded an app on my smart phone that digitally measures the face angle of the pinion and transmission. It is very accurate. Tremec also has a good app for checking pinion angels. The two angles need to be identical and opposite. ie: pinon up 3 degrees, transmission tail shaft down 3 degrees but you likely already know that.
    The rest can be found doing a search as this question comes up every month or so it seems.
  6. clem
    clem
    learn something new every day…………
    Checked it out on tremec’s website, - looks easy !
  7. fabricator john
    fabricator john
    from venice fl.
    at ride height your two u joints should be at the same but opposite angles as in "theoretically" with the car on the suspension if the front u joint angle was downhill 12 deg ( just a random number) then you would want your rear u joint angle to be 12 deg uphill , then the vibrations from the swiveling ujoints will cancel each other out and no vibration , on a leaf spring car i like to add a few extra degrees downhill to the rear pinion angle if ya plan on beating on it to have em line up better when the pinion lifts ..
    fabricator john
    miss you dad
    Dan Timberlake likes this.
  8. gimpyshotrods
    gimpyshotrods
    I had a timer running.
    427 sleeper, 57 Fargo and twenty8 like this.
  9. Mr48chev
    As they said up/down doesn't matter as long as the output shaft and pinion shaft are parallell.
    Back in the 60's and 70's the ricky racer brigade had the misguided idea that the pinion had to angle down at X degrees to compensate for spring wrap at launch and acceleration and they where the ones who were always breaking U joints on the starting line.
    427 sleeper, putz and gimpyshotrods like this.
  10. chicken
    chicken
    from Kansas
    The second from top is normally what you should shoot for.
    Country Joe likes this.
  11. BJR
    BJR
    In the top photo the needles in the bearing caps will not move and will develop flat spots on them. Second photo is the way to go.
  12. 1971BB427
    1971BB427
    from Oregon
    A cheap $8 angle finder from Harbor Fright is a very useful tool for this, and many other things on a car build!
    2OLD2FAST likes this.
  13. Ebbsspeed
    Ebbsspeed
    For you "equal but opposite angle" folks, think again. There is another configuration that works to cancel out the vibration caused by the ellipse formed when a U-Joint is rotated. Driveshaft angles.JPG
  14. vtx1800
    vtx1800
  15. jaracer
    jaracer
    The "W" setup does work however, it only works well when the angles are fixed. I've seen it on long wheel base trucks with multiple drivelines. It doesn't work well when one of the components moves up and down or tilts like a single drive shaft hot rod.
  16. gimpyshotrods
    gimpyshotrods
    That is only true if you have a fixed-mount differential, such as with independent rear suspension.
    If you have live axle, suspension movement will be more than enough to move the needles, and circulate the grease.
