Projects Pins that hold door and window handles in place
Discussion in 'The Hokey Ass Message Board' started by Babyboomerboy, Feb 23, 2024.
  1. Babyboomerboy
    Babyboomerboy
    I have a 1950 Ford and the door and window handles are held in place with pins. You can buy the handles but they do not include the pins. What does everyone use for pins. Thank you
  2. willys36
    willys36
    I cut off pieces of gas welding rod. Check size, can't remember if it is 3/32" or 1/8".
    302GMC, lothiandon1940 and 2OLD2FAST like this.
  3. '29 Gizmo
    '29 Gizmo
    from UK
  4. chopolds
    chopolds
    from howell, nj
    Generic roll pins. You can get ***ortments pretty cheap.
  5. lothiandon1940
    lothiandon1940
    I've used little short pieces of tiny dowel rod in a pinch.
  6. Bandit Billy
    Bandit Billy
  7. 1932tub
    1932tub
    3" nail cut to suit
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve used metal screws too.
  9. Bob Lowry
    Bob Lowry
    Ace hardware, as well as other, have a good ***ortment of roll pins...
    VANDENPLAS likes this.
  10. Kiwi 4d
    Kiwi 4d
    What ever you choose to use ,they can still be a right PIA to remove or install. Even with the supposedly correct tool.
    wheeldog57 likes this.
  11. deathrowdave
    deathrowdave
    from NKy
    I always used a roll pin wire threaded through and twisted , so as not to loose your pin
  12. swifty
    swifty
    I usually go out the back of the shed and select the right gauge of fencing wire to suit the handle LOL
    Have various bits of left-over fencing wire behind the shed but it is getting harder as fencing wire is now smaller gauge and hi-tensile. @1932tub never thought of using nails.
    29A-V8 likes this.
  13. blue 49
    blue 49
    from Iowa
    I think made mine out of #9 wire.
    Gary
  14. gene-koning
    gene-koning
    On my Mopars, I use cotter keys, and bend the ends around the shaft. Easy to install, easy to remove, cheap, and often reusable for a couple of times.
  15. rmcroadster
    rmcroadster
    Nails cut to length.
  16. lostn51
    lostn51
    from Tennessee
    With my last few shoebox Fords I just remove the vent windows all around and do 1 piece gl***. I’ve never had any luck with vent windows :oops:
  17. I just used pieces of steel rod cut to the correct length.
  18. Dennis D
    Dennis D
    I threaded my handles and used set screws in them.
