Projects Pipe anvils show em off!
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Feb 8, 2024.
  1. Who’s got the coolest one ?
    I don’t really want to build several but I need the radius variable. and because of what’s being made I need the end open to slide the parts in and out of the end.
    I’ve got a slip roll but doing them in there a PITA. Too many flips , adjustments generally to much time and too much ****ering around. But it opens
    this is a pipe anvil,
    You certainly could hammer on it but it’s more of a manual slip roll. Push/pull the metal over a radius.
  2. Budget36
    Budget36
    I’ve never heard of a pipe anvil.
    Thanks for sending me to Mr ? Google.
    dana barlow, 56don, Ziggster and 2 others like this.
  3. lostone
    lostone
    from kansas
    I've often wondered about building one with an open end and my thoughts have been as follows....
    1. Build one end with the pipes connected to a heavy piece of plate to prevent flexing.
    2. Actually drill that plate so the tubes go all the way thru the plate as to get a solid weld around the complete cir***ference of the different pipes.
    3. Maybe throwing in some rebar inside the tubes and filling with concrete to further stiffen the pipe to keep from flexing with the unsupported open end...
    That's as far as I got, one downside is it would be heavy BUT I think it would work rather well.
    Also thought about building a standard 3 pipe version, mount the outside pipes lower on the main tube and then mount the pipes on a spinning stand so I can roll which ever tube I want to use up and make it more accessible. Add a pin into the end so once I roll which ever tube I want to use up I can pin it in that position and start prying my metal around it....
    Plan on building one, just don't know which version I want to build...
  4. Budget36
    Budget36
    I just did the Google thing and watch Fitzee make one.
    Pretty cool!
    Fortunateson and Ziggster like this.
  5. Well I be.
    cool
    Tow Truck Tom likes this.
  6. Bump for the morning crowd
  7. continentaljohn
    continentaljohn
    I had to look up what that meant and my interpretation would be a horn on a anvil or similar. image.jpg
  8. flynbrian48
    flynbrian48
    I have a 2' section of railroad track I cut and ground to make a horn, ground the center down to make a flat spot on. It's clamped to a stump with 6 penny nails. Does that count? ;)
  9. Like a manual operated slip roll
    1946caddy and Tow Truck Tom like this.
  10. RMR&C
    RMR&C
    from NW Montana
    Here's mine. Hinged at the wall to fold away. Rotates for position. End cap/support unbolts to slide in/out panels.
    Pipe sizes are 5", 3.5", and 2".
    It's really handy... I've made a bunch of parts with it. Now I want one with bigger pipe!
    dwollam, deathrowdave, fauj and 10 others like this.
  11. Mr48chev
    I thought that was my photo. that is a "Winfield bender" that Gene had the guys in Post Falls make for a cl*** a few years ago.
    they also had a smaller one [​IMG]
  12. A six penny 6d is little more than a brad
  13. It is from a post of yours.
    Seems a “pipe anvil” is a bit of a mystery. I grabbed the first and best picture I could find to give a visual.
    Maybe there’s another name they go by?
    Budget36 likes this.
  14. Mr48chev
  15. TA DAD
    TA DAD
    from NC
    I just recently heard of one. It would be a nice tool to have. I do have a big steel sawhorse and a couple pieces of pipe along with a wooden mallet, I used those to fab up this air cleaner. And it was round when all finished Lol. You can do a lot with a piece of pipe. IMG_1243.JPG IMG_1244.JPG IMG_1245.JPG
    RMR&C likes this.
  16. Los_Control
    Los_Control
    from TX
    Almost ashamed to show it, nothing to brag about on the internet.
    I have a very small 12'x22' garage that is simply big enough to store tools in, I work under the cover of the carport attached to the garage.
    So I made mine 36" small and it mounts in the bench vice.
    I really should clean & paint it ..... I needed it for a particular project, I used it and it worked fine ... I've used it a few times since then and it just leans against the wall til next time.
    I would definitely build another or just replace it if I did not have this one.
  17. dln1949
    dln1949
    Well that’s just too simple. Thanks Los-Control
    fauj likes this.
  18. studebakerjoe
    studebakerjoe
    @lostone instead of all the concrete and rebar why not just put slots in the ends of the tubes and use a removable section of rod or all thread that clamps them together. A washer in between each pipe for spacing. Slide it in tighten up a few nuts then loosen and remove to slide off your workpiece.
  19. Last edited: Feb 9, 2024
    RMR&C and Budget36 like this.
  20. Fortunateson
    Fortunateson
    Yeah, Fitzee makes it simple.
    fauj and Budget36 like this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Must not get used " aggressively" if 6 d Nails hold it in place !
  22. lostone
    lostone
    from kansas
    @studebakerjoe that's a good idea! Never thought of that one and easy enough to do.
    That's why I like bouncing ideas around whenever I get serious about building something...
    31Vicky with a hemi likes this.
  23. Sandcrab
    Sandcrab
    I use mine like Los_Control, just clamped in the big vise. I spaced the tubes with washers and used nut serts on one end to give me an open end if I need to slide a shaped piece off without distorting it.
    Tim, 1971BB427, RMR&C and 5 others like this.
