pitman arm question
Discussion in 'The Hokey Ass Message Board' started by lone wolf, Oct 23, 2007.
  1. lone wolf
    lone wolf
    can i or should i cut the end off my pitman arm and weld another end on it?
    here is where i am at,
    have 78 pontiac steering box on my 41 ford, the 41 tierod end is bigger then the hole in the pontiac pitman arm.
    can i cut the end off the arm and weld the 41 fords end on it? if so would it be safe to do?
    i did go to a machine shop to see if they would drill it out bigger but they didn,t want to mess with it, i also went to a auto parts to see if i could match a chevy tierod end to the ford drag link, no luck there.
    anybody have this problem and if so, how did you fix it.
  2. tomslik
    tomslik
    why not retaper the hole?
    be a damn site safer than splicing a new end on it....
    reason i say this is, if you have to ask if you can, you better not do it....
    i'm not worried about YOUR ***, it's the people you hit...
  3. zoomy
    zoomy
  4. alchemy
    alchemy
    PM me, maybe I can ream it for ya.
  5. Dan10
    Dan10
    from Joplin
    It is very common to weld a new end on to an old arm for converting to Toyota steering box on 48-60 ford trucks.
  6. Probably your best bet, instead of spneding $80+shipping for a 1 use item, without experience you may goof it and ruin the arm. Make sure you set him up with a few cold ones for helping out!
