Hot Rods pitman arm
Discussion in 'The Hokey Ass Message Board' started by V4F, Dec 27, 2012.
  1. V4F
    V4F
    from middle ca.
    does anyone make custom pitman arms for model "A" ?? square hole at the steering box ................. thanks .. steve
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    There are plenty of Model A pitman arms out there you can make one up from. They are forged steel like pitman arms on all other cars too. Easily cut, heated, bent, and welded liek all Ford quality alloy forgings.
  3. el Scotto
    el Scotto
    from Tracy, CA
    Yep, they make new stock and short ones to speed up the steering.
    Make sure you get a forged one! :D
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Wouldn't a shorter pitman arm slow down the steering?
  5. V4F
    V4F
    from middle ca.
    a shorter arm (1 1/2") makes much easier to steer . im needing a longer bent arm . i used my stock arm to test it , but after modifing it is to short . it steers great but no turning radius . i need one longer made of flat steel so i can modify it to fit . lots of arms out there , but no square ends for the steering box . yes i have thought of the many aftermarket boxes , but $$$ are short for me ...... thanks .. steve
  6. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    As said,you can just add some to it,or there is another way,by shorting the arm on spindel will give you more turn.:cool:
