Technical Pits in steel wheels
Discussion in 'Traditional Customs' started by Mrmeenyo, Nov 25, 2016.
  1. Mrmeenyo
    Mrmeenyo
    Can anyone tell me how I can repair the pits left from rust on some old Ford wheels?[​IMG]
  2. High build primer?
  3. Mr48chev
    Sandblast and use the high build primer is what I would do. Sand blast to get the rust out of the pits so it doesn't rust right back in a short period.
    Mrmeenyo likes this.
  4. manyolcars
    manyolcars
  5. deucendude
    deucendude
    from norcal
    JB Weld. Then primer.
  6. 1946caddy
    1946caddy
    from washington
    Itching primer followed by high build primer and paint.
  7. nunattax
    nunattax
    fine sand blast ,etch primer , ,high build primer,lots of sanding paint the mother
  8. JB weld cracked on a steering wheel I re-did after encountering some heat...I wouldn't use it again..
  9. Blast them for sure!
    Pits thin/weaken the metal so be sure they are strong enough to use. You might even find a hole or 2 to weld up.
    CRE primer by PPG. (Corrosion resistant epoxy) and it builds like crazy and sands easy. It's epoxy and id like it better than 2k urethane on pitted stuff.
    Your tire mounting guy will still need to be careful
  10. Mrmeenyo
    Mrmeenyo
    I was reading about lab metal. Anyone try that yet? It's even able to be powder coated.
  11. clem
    clem
    Would powder coating cover it well enough ?
  12. nunattax
    nunattax
  13. Truck64
    Truck64
    from Ioway
    Those are "innies", made till '64... Anybody reproduce those? The usual outlets make "outies"...
    y'sguy likes this.
  14. if the pits are just cosmetic, i would use, yes i am going to say it, plastic filler or the dreaded bondo. a quick swipe with a small amount on the end of a finger will fill those quick. if careful and with practice, you should be able to apply so it needs little sanding. i found this to be the quickest way, then prime, sand, paint.
    Mrmeenyo and The37Kid like this.
  15. bingo! JB weld original formula, smear it in there and sand it smooth. I use it a lot for powder work and filling pits and then baking.
  16. depends if you go to a shop that puts it on silly thick or if you go to a shop that does art with powder.
    It can be sprayed heavy, but it always looks like poop and the powder may bridge across the gap of center and rim.
    Sometimes, on small blems, I will use a layer of powder, bake to cure and then wet sand smooth and powder again, using the first layer to fill in the tiny pits. If they are to deep, but rim is still good, use JB weld. then powder
    clem likes this.
  17. clem
    clem
    Thanks, some of the wheels I have had done have obviously been sprayed heavy.
    Today I have learnt something.
  18. Mrmeenyo
    Mrmeenyo
    Thanks everyone, so you have been able to powder JB weld? I was told no but that guy is a purest and doesn't always understand cosmetic work.
  19. Mrmeenyo
    Mrmeenyo
    Yes these are innies and have been very hard for me to find. I really want to make these work. I got them pretty cheap and willing to spend some money to get them back to their original glory. [​IMG]. This is what they looked like prior to my work on them. [​IMG]. This one came out perfect.
    bct likes this.
