Technical Pittman arm question
Discussion in 'The Hokey Ass Message Board' started by BamaMav, Aug 4, 2021.
  1. BamaMav
    BamaMav
    from Berry, AL
    So, I finally got to drive my car today with the swapped in Saginaw power steering box. The box came from a 85 Firebird, the Pittman arm is off a S 10 pickup, column is GM with a stock 67 Chevelle wheel. The steering is quicker than the worn out manual 1947 Lincoln box was and smooth as silk, but I have lost a good bit of turning radius, it doesn't turn as sharp as the old manual box did. I'm thinking maybe I need a longer Pittman arm to push the cross steer rod a little farther? Sorta afraid if I put a longer Pittman arm on it it won't be parallel with the tie rod anymore, and I don't want to introduce any bump steer. Stock Lincoln beam axle, cross rod tie rod end bolted right to Pittman arm after enlarging the hole just a bit, same radius turning both directions, shorter than it was. I can get used to it, just wondering if I can improve it a bit? Thanks
  2. squirrel
    As long as the drag link (cross steer rod) is mostly parallel to the ground, it should not add any bump steer.
  3. alanp561
    alanp561
    It's not going to take a heck of a lot more length on the Pittman to tighten up the turning radius. A quarter of an inch will make a lot of difference.
  4. mgtstumpy
    mgtstumpy
    A short pitman arm has a narrower sweep (Arc of travel) than a longer pitman arm. Will a longer arm work with your setup without fouling and interfering with geometry?
    Exaggerated example
    Elcohaulic and Hnstray like this.
  5. indyjps
    indyjps
    If youve ever driven a third gen camaro or firebird the turning radius is not great anyway.
    From memory an 82-93 S10 2wd steering box should bolt in place of a third gen box. Please verify its been a while since I looked at all the options.
    Third gen boxes had an optional fast ratio 12.7 to 1. Standard third gen boxes were a slower ratio, S10 is 14 to 1 with more travel.
    Third gen f body and S10 Should all be saginaw 800 boxes, there are differences over the generations, when they switched from SAE to metric lines.
  6. Mr48chev
    You are on the right track but you also need the idler arm that matches the pitman arm length wise.
    buffaloracer and studebaker46 like this.
  7. gimpyshotrods
    gimpyshotrods
    He's using it for cross-steer on a beam axle.
    seb fontana likes this.
  8. gimpyshotrods
    gimpyshotrods
    Not sure what the center-to-center length of your current pitman arm is, but this is a possible subs***ute:
    https://www.ihpartsamerica.com/stor...ySlJCfKUjDbv0Z8VnzikcD-HMKfBJLthoCjVgQAvD_BwE
    SS327 and Hnstray like this.
  9. nobby
    nobby
    s10 is i think 6 inches on centres -
    jeep grand cherokee
    1. has the same clocked straight ahead splines
    2. has a similar drop
    3. is longer i think
    4. has a small taper for tie rod - I.E. can be enlarged
    when you buy a pitman arm and get the old packet, it listst the lengths on the in a check box type affair
    I am pretty confident that 6'' on centres is the starting point.
    I have sold the grand cherokee one i had, but am sure it was longer.
    ooh, a 70-71 pontiac full size pitman is 6 and an 1/8
    fits the power saginaw
    has the same early ford taper at 1.5 inches per foot
    is the input length on the double eye side steering arm 7 inches?
    i say that because with a 37 spindle, 6 1/8 pitman and a quick 800 box - its perfect
    1 1/4 turns lock to lock and quick
    Blues4U and mitch 36 like this.
  10. BamaMav
    BamaMav
    from Berry, AL
    I'll have to do some measuring. I started with the S10 box, but when I got it all hooked up it had hard spot just off center, so I went with the fire bird box which looks identical and swapped the Pittman arms because they were the same length instead of having to open up another one for the rod end.
    Sounds like I was correct, a longer arm should give more turning radius with a slower speed. Now to do some looking around....
    Thanks!
  11. squirrel
    when you say "more" turning radius, do you mean "tighter" turning radius? Because "tighter" is "less".
    Hnstray likes this.
  12. BamaMav
    BamaMav
    from Berry, AL
    Tighter? Right now, it is so wide, I had to back up and go again to make a turn out of my yard that I should have been able to make in one swing. I guess I wasn't wording it correctly. It takes too big an area to turn, so I need to push the draglink farther to cut the wheels farther to close up the turning distance.
    Hope that makes sense!
  13. 1971BB427
    1971BB427
    from Oregon
    Unless you went to a much longer arm, the geometry should not change. And length of the arm has no affect on what we refer to as bump steer.
    As the arm moves in an arc, it is always less than parallel to the tierod and axle. So starting out slightly longer means it might even be a bit better, not worse. I wouldn't be concerned about going as much as 2" longer, as long as the current drag link is parallel to the tierod now.
  14. nobby
    nobby
    it may be that the box itself will only travel that far?
    i think i have seem 800 saginaw sector shafts with both 3 teeth and 5
    what traval at the spindle do you need to see so the nut lands on the spindle stop
    -is it about 2.5''
    if the box only goes 2'' then its no good awyway?
  15. BamaMav
    BamaMav
    from Berry, AL
    A little update:
    I checked the pittman arm on the car, the one I took off the FBird box, and the original 47 one, all three are the same length. I haven't driven the car again except here in the yard, when I noticed it seemed to cut tighter to the right than the left. This afternoon, I was taking my steering wheel off to center the spokes, and after I did that, I did a left from center and a right from center turn, and found out I have 1 1/4 turns left from center, and 1 3/4 turns right from center. Egg on face!
    Apparently, I didn't get the box centered when I put the pittman arm on. Don't know if I moved it a smidge, or just missed getting it centered. Going to take the pittman back off when I get a chance and see if the splines will allow it to mount centered, then adjust the cross link to fit.
  16. Canuck
    Canuck
    Can always try your original Ford arm, I think they are the same shaft and spline as the GM arms, splines might be at a little bit different angle.
    Steering stops inside the box may be shortening your radius, maybe a earlier box housing could be utilized to get a larger turning radius.?
  17. dalesnyder
    dalesnyder
    When they changed to to o ring lines they also changed the flat spot where the steering rag joint goes. I had to grind a new flat to align the box correctly. If you just move the steering wheel then the turn signal cam does not self cancel correctly.
  18. BamaMav
    BamaMav
    from Berry, AL
    Good to know, may try that. Do they have the large flat spot in the splines like the GM box?
    I'm not worried about that end, I'm using a U Joint so it can be placed anywhere. Wondering about the flat spot on the pittman arm end if it will allow me to reposition it.
  19. Canuck
    Canuck
    Some of my notes from years ago, nothing verified. Check comments about internal stops.
    - 1982 or 86 to 92 Comaro Z-28/firebird Trans-AM are 2 turns (12:1) lock to lock, Use original end cap to get the right stops on 2 turn boxes to decrease turning radius.
    - Later model boxes (1980 and up) use “O” rings instead of flared input and output lines.
    - Later model internals can be swapped into early boxes to eliminate problems with line fittings and stops or pump can be modified by changing outlet valve (this requires verification) or swapped to accept "O" ring hosed.
  20. gimpyshotrods
    gimpyshotrods
    The double-wide splines inside the Pitman arm hole can be eliminated with a triangle file. That will give you 360º of freedom, and more possibilities for interchange.
    Hnstray, Tman and 427 sleeper like this.
  21. BamaMav
    BamaMav
    from Berry, AL
    Thanks Gimpy! That was something I couldn't remember fully, I was thinking there were a wide spline either on the box or arm or both. I need to move the pittman about 1/4 turn to have an equal 1.5 turns each direction.
    I need to pick up a triangle file and give the hole some loving p***es.....
    Then hope I have enough adjustment on the tie rod ends to connect back.
    Oldiesmiles, dirt t and 427 sleeper like this.
  22. gimpyshotrods
    gimpyshotrods
    The sticky-outy wide bit (technical term) is always on the pitman arm. You just need to manually cut your own splines.
    Even if you go a little past it's fine, there are more than enough machine cut ones.
    SS327 and 427 sleeper like this.
  23. BamaMav
    BamaMav
    from Berry, AL
    Took a look at it this morning, discovered some hack had welded the nut and the arm to the box shaft! Some people need their thumbs cut off!
    I looked at my other GM arm, I see what you're saying on the wide splines, one on each side, 180 degrees apart. I'll practice on it before I take the one on the car off and recut it. Thanks again!
    And I like that technical term from a technician, LOL!
  24. topher5150
    topher5150
    So the original 47 pitman arm will fit a GM box? Will it hit the tie rod?
  25. BamaMav
    BamaMav
    from Berry, AL
    Forgot to update this thread.
    I cut the wide splines off the arm and was able to center it so I have the same amount of turns lock to lock on both sides. But it still doesn’t turn tight enough. Measured the pitman arm, 6” between the holes. Been looking around, found a universal 7” centers street Rod pitman arm at Speedway, but they are out of stock and don’t know when they will get any in. Found a Bourgson arm on eBay, so I may just go that route. Hope the extra 1” gives me a little tighter turning circle.
    Weather has gotten warmer, so I have the car up on stands so I can get some stuff done underneath that I want to change. Maybe I can get some miles on the old girl this year. Didn’t put but about 30 miles on it last year after I finally got it going again.
    gimpyshotrods likes this.
  26. Mimilan
    Mimilan
    Just make sure there is enough room for the pitman arm to swing without the drag link contacting the tie-rod. [below]
    On a beam axle , the angle [looking down] is irrelevent. It does not affect ackerman or bump steer .
    Just make sure the balljoint centre of the pitman/drag link is the same height as before.[the height affects bump steer]
    Even on parallel drag-links to tie-rod ,the drag link is only parallel in the straight ahead position, and the pitman arcs opposite to the steering arms
    But before you jump-in feet first, turn the steering full lock. Then knock the ball joint out of the pitman arm and see how much more steering you would gain. [on both the steering box and the steering knuckles]
    It might just be the steering stops [and you've never turned this so sharp before with the "Armstrong steering"]
    Hnstray and clem like this.
  27. topher5150
    topher5150
    Check Pete & Jakes 3020, but you have to bend those.
    Anybody else come up with any clever solutions?
  28. scrappybunch
    scrappybunch
    from nj
    The saginaw box's have travel limit stops. One is on the aluminum end cap, has 3 pads that can be ground down, or replace with one that has shorter pads.. The other is a steel ring in the bore, that can be removed. Won't cost anything but a seal kit, and the time to take apart.
    ffr1222k likes this.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you remove the o-ring from the bore , what keeps the box from over -turning to the point of damage ?
  30. I know the stock Ford pitman arm will fit a GM manual box. I had a '64 Chevelle manual box in the '38 Ford pickup with the stock Ford pitman arm on it. I also found that wheel offset had an effect on turning radius and ease of steering.
