Technical Plasma cutter into a CNC machine?
Discussion in 'The Hokey Ass Message Board' started by BIGEVIL, Apr 17, 2023.
  1. BIGEVIL
    BIGEVIL
    Hello wise forum.
    I have seen a few kits that help your existing plasma cutter turn into a plotter / CNC machine?
    I'm not sure where to start. I'm happy with my cheap Harbor Freight plasma, just looking to do a little more accurate fab work.
    I'm mildly computer literate and could ***emble it if it came in kit form. I do not have an extra computer laying around though.
    Has anyone done this? Any advice is appreciated.
  2. Tim
    Tim
    from KCMO
    I bet the garage journal has threads on this exact topic. Should be a link at The bottom of the page if your not already familiar
  3. Budget36
    Budget36
    A member had a post going a few months back on how he built his. What parts he used, etc. I lost track of the thread and don’t know if he finished posting all the info.
  4. K13
    K13
    Hellbentrodder likes this.
  5. AccurateMike
    AccurateMike
    I did something similar once. Was long ago (20+ years). It is easier now.
    Mike
  6. Budget36
    Budget36
  7. nobby
    nobby
    buy a dell optiplex mini i5
    win11 it
    go on u tub and search illustrator cs2 download
    -install make sure its working.
    down load sheetcam tng demo
    Downloads (sheetcam.com)
    download mach 3 demo
    Newfangled Solutions Mach3 (machsupport.com)
    join the mach 3 forum.
    what you might have seen is a guy converting a little laser cutter into a plasma.
    hmmmm
    buy automation parts
    FIRSTLY - you cannot plasma a 3 axis style cartesian chinese table as the ball screw runs up the middle of the bed - not ideal.
    you cannot see through the bed - but the 'ba;lscrew is up the middle under the bed - not really plasmatastic, however this would work \/
    Precise Ballscrew CNC Router 3-Axis Machine Pre-***embled Kit | eBay
    the hardest part of it all is making the gantry system.
    next, the elastic trickery
    first buy 6 of these
    Short Spring Plunger Actuator Enclosed Limit Switch AC 240V 5A 190459741453 | eBay
    buy sheilded cable for these limit switches
    moving on to the motors
    a realatively new thing is closed loop stepper motors and drives
    now you need 4 because you are having a up down z axis
    =1
    a side to side cross beam axis, the y axis
    and the main axis, its called the x axis, BUT you are having an extra what is known as slave axis 'A' with its own motor abd ball screw
    so you need
    4 motors
    4 drives - drivers
    power supply for the motors and drives
    AC 220V DC 36V 15A 20A Adapter Power Supply Transformer Switching for Led Strips | eBay
    a mach 3 controller with 4 axis and NOT THREE
    closed loop motors and drives are really quite expensive
    nema 23 - 2.3;; motors x4
    NEMA 23 2.8A 127oz-in Stepper Stepping Motor Great for DIY CNC and CO2 laser | eBay
    nvem 4 axis controller
    4 Axis NVEM CNC USB Motion Controller 200KHZ Ethernet MACH3 f/ Stepper Motor『EU』 | eBay
    tb6600 drives x4
    TB6600 Driver Single Axis 4A Stepper Motor Controller 9~40VDC CNC Drive Module | eBay
    36v 15a switching power supply
    e stop switch
    eec ch***is plug
    box for electronics
    4 wire motors, you dont need 8 wire motors for plasma
    if using the network version of that card, you have to connect it to a switch, and not direct, crossover cable wont work either, pc needs to be a server, ip ***ignment cobblers
    the wireing of controller to drives to motors to psu is easy
    illustrator - page set up to cut area
    export as dxf into sheetcam
    convert to g code c++ basic
    open in mach3
    cycle start
    you take one of these bolt solid aluminium 80mm by 15mm around, add ballscrews, amke a y axis, buy a z axis
  8. ottoman
    ottoman
    from Wisconsin
