Plasma cutter or tig welder????
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Aug 24, 2005.
  1. Mike Paul
    Mike Paul
    Looking to add another tool to my home shop. I can only afford to buy one or the other. I have a torch,chop saw,sawzall,mig weld and arc welder. I would like a tig to be able to weld aluminum and steel, but also like the nice way a plasma cuts without alot of distortion. Which one do you think I would use more?
    I'm looking to spend around 2K so any suggestions on makes and models would be appreciated. Thanks.....Mike
  2. skumbag
    skumbag
    i dont know anything about makes or models, but i would rather have a tig.
    i wish i could afford one for my house but i'm a poor *******. :(
    i think i've almost got my boss talked into buying one for our shop. :D
    later, matt
  3. Paul
    Paul
    Editor
    I use my plasma cutter a lot
    but rarely use my tig.
  4. happy hoppy
    happy hoppy
    my plasma cutter is handy, but a tig is near the top of " get next " list.
  5. If you spend your money, right, you can get both for 2K.
    I bought my Miller GoldStar for $600 and my Snap-On plasma cutter for $325... at AUCTIONS.
    Neither one has skipped a beat.
    If not... get the plasma cutter.
    Price the consumables for each model, before you buy... some will break you.
    JOE:cool:
  6. dodgerodder
    dodgerodder
    I guess it really depends on the type of fabrication you do the most-frame building, body work, etc. I always wants a plasma cutter, and a year ago I finally bought one. I've probably used it a dozen times, and not for things I HAD to have a plasma to do, but just becuase I have one. For me it hasn't been a must-have tool. And by the time I drag out the 220 cord, hook up compressed air, and set it up to use I could have been done using my bandsaw.If you are looking for a cutting tool my bandsaw is my most-used tool in my shop. I can cut box tubing, angle, flat stock, miter cut box tubing perfectly etc. My chop saw hasn't been used since I got the bandsaw, that and my mig welder or the two tools I could not do without.
    I would love to have a tig, but to get one heavy enough for ch***is fab and regular use is easily $4000, and not with all the bells & whistles. It is a slow, much more tedious process then mig, but the welds can be beautiful for a good weldor.
    Its a tough call though, and 100 guys will have 100 different opinions. Its at least cool to know you'll soon have a new toy of some sort!
  7. hillbillyhell
    hillbillyhell
    For 99% of people, I'd say a plasma cutter. It's just so damn versatile that I think I'd have a hard time living without it. My TIG, I also find indespensible, but only when I'm doing ch***is fabrication or detail work. So unless you plan to build a ch***is and are so **** you want to TIG in all your boxing plate, or you build loads of ladder bars/hairpins/nerfbars/stuff like that, the novelty will soon wear off a TIG.
    With all that said of course, there's always some little job that pops up that having the TIG makes possible. :D
  8. RustikRods
    RustikRods
    If money were no object i would go with a TIG. As for me, i rarely come across anything that a sawzall or band saw wont handle. But for $2,000, you cant get a decent TIG. I have a Miller 250 and it was about $4,000 with all the goodies that go with it. TIG welds are much cleaner and more precise than MIG welds. You have more controll over the penetration with a TIG. You can also weld stainless and aluminum as well as steel. So if you can s****e up another 2 grand, i would go with that.
  9. Andy
    Andy
    I will sell you my Firepower plasma cutter for $600. List $1400. Made in Fort Worth. Used about 1/2 hour. Except for a smuge on cutter tip, it looks brand new.
  10. hillbillyhell
    hillbillyhell
    Since when is a decent TIG 4 grand?? We have two Miller Synchrowave 180s, and they were like $1500 a pop. I guarantee that there is no hotrod related welding job that cannot be accomplished, and accomplished well with said $1500 machine. Sure, water cooled torches and thumb controls are great, but not really mandatory....
  11. willowbilly3
    willowbilly3
    from Sturgis
    Maybe you should check into a Henrob. I have never used one but many of the guys here have and there have been threads on them or just google it and read all about them.
  12. Slag Kustom
    Slag Kustom
    i have both and rarely use either TIG only comes out for aluminum and plasma cutter i cant remember.
  13. PurHell
    PurHell
    from So Cal
  14. noboD
    noboD
    Go to the plastic, buy both!
  15. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    if youfind the right tig it should be able to do both with just two difrent heads on tig torch and a plazma head all you really need to turn tig in to a plaz is comressed air and a plaz head
  16. noboD
    noboD
    Wha???
  17. momentumfoto
    momentumfoto
    from Yes
    hahah plazhead who? hahah yeah wow...??
    Plasma cutters for sure... they are the dogs bullocks... you allready have the arc welder...
  18. RustikRods
    RustikRods
    Whats the duty cycle on those welders?? Nothings worse than having to wait for a welder.
  19. poop
    poop
    Hey ThRead,
    It's sure is a nasty World, would you rather cut something apart, or weld it back together/ fab a part? THe InVerteR ac/dC WELDERs ARE PRETTY Awesome, & only weigh around 40 pounds and you may even chang the hertzzzz, so you may get a finer bead.
    Good Luck with your choice
    pOOp
  20. THECHICK
    THECHICK
    yeah he is right- what do you do more of? And check out auctions and (I dont know if you have it arounhd you) Craigs list. www.craigslist.org
    We found stuff there -sometimes for free
  21. JOECOOL
    JOECOOL
    You will save time with a plasma, more than likely spend more time welding with a TIG. If your time is valuable then the plasma will probably be the best deal .
    As far as prices go ,I bought my Lincoln 250 air cooled TIG at a community College auction for $860 without bottle. My plasma was less than $1200.(cutmaster 35).
    The Tig Consumables can be a factor if you are learning and screw up a lot of Tungsten.A lot of different size collets, tungsten for Aluminum and steel, filler for aluminum and steel,Bottle and gas can raise the Tig price considerably.I probably have $500 in that stuff.
    Best of luck.
  22. Henrob...cuts like plasma and welds like TIG.
  23. fab32
    fab32
    If you haven't got a high production shop I would tend to agree with Johnny Fast. The Henrob will do what both of the units you are talking about and if you have basically a hobby shop it might be the way to go. If however you're a high volume metal working facility you really need both the Tig and the Plaz. Every situation calls for a differnt solution. If your having a problem deciding I'd wait and pay atention to your most urgent need, then fill it.
    Frank
  24. Bass
    Bass
    from Dallas, TX
    I would and did buy the TIG first.
    I look at it based on the quality of your finished product. Nobody will be able to tell if you cut out a bracket with a plasma cutter or not, but they'll sure as hell be able to tell that you TIG welded that same bracket once you get good at using the TIG.
    As far as brand goes...Miller all the way. Most of the time you can find a good used machine for WAY less than a new one. I have an older 250 amp water-cooled Miller (actually Miller/Airco) Dialarc...it's probably 20 yrs old, and never misses a beat.
  25. tisdelski
    tisdelski
    i`d buy a tig and a henrob. i paid 600 for my miller 330/abp and 1000 for my used 180 sd. the henrob costs about 350 with the x-tra 0.5 tip for sheet metal it cuts great. shop around this stuff is out there. gary
  26. Roothawg
    Roothawg
    What does something like that run Brian?
  27. Bass
    Bass
    from Dallas, TX
    I've got around $1500.00 in my set-up, including the bottle, but not including the consumables like tungsten, cups, and filler rod. I bought it from a local used welding dealer/ repair. They went through it before I bought it to make sure it was OK...I've had it for about 3-4 months, and I love it so far.
    The same machine would be about twice what I paid if you could still get one new. The newer (Miller) Synchrowaves are probably a better machine, but the old Dialarc can do anything I ask it to do.
  28. Brickster
    Brickster
    Now I have access to a number of cutting tools and rarely find my self using the plasma anymore. When I was working out of my own garage with the borrowed plasma from my former place of employment I used it all the time.
    I use the TIG for almost everything.
    There have been some very good points brought up and a lot to consider. In the end you will need both anyway and you really can't go wrong with either one.
    I don't know if anyone asked yet. Do you already know how to TIG weld? or are you going to need some time to learn? The plasma is almost a no brainer for opperation.
  29. noboD
    noboD
    Not trying to **** in on B***, but I bought the exact same setup. Paid $500, hardly ever used ,leather cover for hoses, several boxes of spare parts worth couple hundred by themself.
  30. ElPlymino
    ElPlymino
    from Orcutt
