Technical Plasma cutting services (Need Olds Rocket front mount)
Discussion in 'The Hokey Ass Message Board' started by tubman, Jul 28, 2015.
  1. tubman
    tubman
    Anyone on here do plasma cutting or know someone who does? I need a set of front motor mounts in the old Hurst pattern to fit an Oldsmobile Rocket. I have looked and looked and no one seems to have them anymore. In looking at the engine and frame, I believe I could make a set of patterns that would fill my needs. I suppose I could manually cut and grind them myself, but that seems to be a lot of unnecessary work. I don't have a plasma cutter, and at this stage in my life, couldn't justify the expense.
    Anyone out there do this, and if so, what are the requirements for patterns (materials, etc.).
    Thanks
  2. cornfieldcustoms
    cornfieldcustoms
    i do cutting in house. all i would need is a good card board pattern of the parts you would be needing
  3. F&J
    F&J
    Figure out how to change your thread****le to "where to get repro Hurst mounts for early Olds"
    There is ebay guy who makes them as well as Cad mounts. They are perfect, and one hamber says they are better welded and finished than orig Hurst. I bought some 3 years ago, it was $55 then, plus shipping.
    I don't get on ebay now, so I forgot the guys store name, but the Olds guys will help with that, if they see this thread.
  4. atch
    atch
    Another source is 51 Hemi J here on the H.A.M.B. He cut some absolutely beautiful brackets for me. I don't know what he uses, but I don't think it's plasma. Whatever it is it looks finished when it comes out of his machine. I didn't even have to grind/sand any edges before painting.
    NOT knocking cornfieldcustoms; just giving out information.
  5. tubman
    tubman
    Hmmmm. I've searched every possible way I could think of and can't find them. Is he still making them? Anybody know who it is?
  6. F&J
    F&J
    If you can't find a set or that guy, PM me in a few days. One of my "clients" bought a second set just for chassis mockup, ... he already had a painted set on a restored motor...and wouldn't let me use his pretty ones :)
  7. Champscotty58
    Champscotty58
    @cornfieldcustoms does excellent work for cheap. The parts coming off of his plasma table look laser cut and welded parts are top notch. Definitely give him a shout.
  8. 2racer
    2racer
  9. ffr1222k
    ffr1222k
    Deto on the hamb has as his signature that he does laser cutting
  10. Member 'Prewarcars4me' also has a plasma table.
  11. tubman
    tubman
    Looks like lots of ways to go. Thanks guys!
