Plasti dip tool handle coating prob
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, Apr 6, 2011.
  1. unkledaddy
    unkledaddy
    I bought a 14.5 oz can of Plasti Dip to redo a couple of pair of Klein linesman's pliers/cutters. Not having used it before I read the label thoroughly......................but I never saw the forest for the trees!
    http://www.plastidip.com/home_solutions/Plasti_Dip
    Here's the problem: You can't have two tool handles coated individually to the same length if the first one goes to the bottom of the can.
    The viscosity of the Plasti Dip is such that a lot of it is pulled out each time a handle is coated, lowering the liquid level by as much as 3/8".
    I couldn't get both handles in the can at once, and tipping the can isn't
    the answer. Plus, one coat isn't enough and each successive coat will be shorter.
    I guess two of the tall 14.5 oz cans (one for each handle) is the cheapest way out.
    Have a nice day.
  2. After you dip the first handle, put some marbles in the can to bring the level back up and then dip the second one.
  3. 13
    13
    from Sultan, WA
    Yup - that's what I did. 2 cans side by side, 1 handle to a can. Hopefully they diminish at the same rate
  4. Some of you folks are way too ****.....................
  5. tommy
    tommy
    Mark where you want the coating to stop on second handle to match the first, insert it and add clean pebbles or BBs until the level rises to your mark. You must have a beautiful set of tools if that bothers you that much.:D
  6. unkledaddy
    unkledaddy
    How does that work?
  7. ALEISTER
    ALEISTER
    I just hope you remember to do your longer pliers first, then work towards the shorter ones.
  8. oldsrocket
    oldsrocket
    It works by dispacement. Putting the marbles in replaces the space that the fluid can take up, therefore the fluid has nowhere to go but up, thereby raising the level of the fluid.
    Think about when you get in a bathtub- the water raises doesn't it? That's because you are displacing the water.
  9. unkledaddy
    unkledaddy
    That's fine for only one coat.
  10. #1 Kawboy
    #1 Kawboy
    from Fl
    I can't believe I read ALL of this !! Sheesh !! REALLY ??
  11. unkledaddy
    unkledaddy
    I know but he raised the floor with the marbles before he dipped.
  12. hustlinhillbilly
    hustlinhillbilly
    from ohio
    Unless it's my ex-wife. She was so fat, when she got in the bathtub, the water in the toilet rose.
  13. ALEISTER
    ALEISTER
    Try transferring contents to a smaller diameter can each time you dip.
  14. nofin
    nofin
    from australia
    Plasti dip can be painted on with a brush. It smoothes out as it sets. Or you can buy Plasti dip spray cans.
  15. ALEISTER
    ALEISTER
    You know they sell pliers that have the plastic on them already.
  16. lothiandon1940
    lothiandon1940
  17. I have to wash my hands 3 times every time I got to the bathroom.
  18. Greezeball
    Greezeball
    Instead of f*#king around with that **** I just buy the slip on handles Klein sells. Their nice and cushy too. Better than the stock ones and better than the dippidy do.
  19. stude_trucks
    stude_trucks
    Sounds like you need a bigger can, or something else to do with your time.
  20. ramrod2624
    ramrod2624
    simple soultion..... Klien tools come already coated. Go buy a new set of pliers. look at the time you spent trying to figure out how to do it with the plastic coating, your time on the HAMB ,then theres the time it takes to coat the damn things, then look at what your time is worth and I bet its cheaper to buy new.
    just my 2 cents....no offense....
  21. Greezeball
    Greezeball
    Bwaaaahahahahahaha! That's some funny **** there.
  22. You could always just dip your fingers. That way EVERY tool you grab will have a rubber handle!
  23. Blue One
    Blue One
    from Alberta
    There's one tool you don't want to dip ;) The stuff will not make a good condom :D
    And no I do not know from personal experience !
    I'm gonna buy a can of black to restore the foam grip of my slightly worn Grant steering wheel.
    I have a vintage Grant wheel with the finger indentations on the rear, they don't make them any more.
  24. unkledaddy
    unkledaddy
    Thanks fellers that's the info I needed.
  25. Another use, I dipped the spark plug wire holders on a 409 valve cover I restored. Looked like factory when I was done:)
  26. Nevala
    Nevala
    This is perfection.
  27. stealthcruiser
    stealthcruiser
    One word.............................Heat shrink tubing..................
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    Done.
