Plastic ABS interior
Discussion in 'The Hokey Ass Message Board' started by butch27, Jan 21, 2011.
  1. butch27
    butch27
    I'm doing the T Bucket interior. Any thoughts on the 1/8" ABS panels for attaching the upholstery to? Does it warp in the Sun . Would Luan be better?
  2. skipstitch
    skipstitch
    I've used both... for my $$$, the ABS is great in a car that will get wet from time to time. I've never had an issue with warpage from the sun.
  3. hotrods247
    hotrods247
    i have used in a few cars works great ......but have never used in a open car i dont think it would be a problem i have tried to heat it and bend it with a heat gun it takes alot to get it to bend... good luck
  4. ABS over Luan...hands down. Especially in a bucket...
  5. Dipper Jr
    Dipper Jr
    from Indiana
    ABS is what I'm going to use in my roadster. Pretty cheap at $32 for a 54"x103" sheet that is .060 thick or $62 for .125 thick. Local plastic shop has in stock, only comes in black.
  6. butch27
    butch27
    Thanks Guys: Can I heat gun bend it around the sides of the inside of the body?
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ive used the ABS and the Board...i'd go ABS hands down on a car that might see water on the inside..it also seems to be a bit more stable product and easy to work with.
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yep:cool:
    compound curves can be a bit of a ***** though
  9. 32v
    32v
    from v.i.
    there is a plastic product called centra works good , you can actually bend it in a brake (one direction only)
    wayne
  10. 1940rpu
    1940rpu
    Anybody know of a source for this? Southeast Michigan or online would work.
  11. POLYFRIED 35
    POLYFRIED 35
    I think that's Sintra ... Google'n the other may lead to a dead end.
    http://www.tri-dee.com/sintra_plastic_pvc.htm
  12. 53sled
    53sled
    from KCMO
    ABS sheets can be ordered from mcmaster carr, eplastics, amazon or the local sign shop.
    http://www.mcmaster.com/#abs-sheets/=ar1l5v
    smooth, textured
  13. mj40's
    mj40's
  14. Troyz
    Troyz
    1/8" ABS works great. I just finished making all the panels for my rpu. It is really easy to contour with a heat gun & if you feel like getting tricky you can use a small bottle of map gas to heat it hot enough to mold it around objects, in my case it was a mastercylinder sticking through the floor. (poor man's vacuum mold) My friend that has been doing upolstery since the 50's turned me on to it.
  15. 1940rpu
    1940rpu
    Thanks mj40,
    I missed your post the first go around but it is very helpful. I was wondering how well this stuff glued but it sounds like it uses all the same techniques as using board. The snap idea in there is great as well. I have always hated the wire clips but had not come up with anything better.
    sweet truck by the way.
  16. 1940rpu
    1940rpu
    Thanks to everyone else for the sources. Looks like there is a range of prices. I will check locally as well to try to save the shipping.
  17. butch27
    butch27
    EZBoys said they had free shopping when I inquired. Cool
  18. 325w
    325w
    ABS is great for interiors. Makes real good door pads. Can be cut with a shear if you have one.
  19. butch27
    butch27
    I'm also looking for a place in SE Michigan.
  20. PBRmeASAP
    PBRmeASAP
    Ok, what's the best thickness? 1/16 or 1/8?
    I've got an open car that i'm going to start messing with door panels, and the seat back with compound curves. What would be the best method of adhering the vinyl? Simple spray adhesive? what about foam then vinyl?
    Full of questions i know, but i was planning on using luan till i found this thread.
    What have you guys used to attach it to the door frame?
  21. 1968FED
    1968FED
    from Goddard KS
    I would use the 1/8, regular trim adhesive works very well you can glue vinyl or foam to the ABS. I did the door panels, headliner and the curved areas behind the seats of my 33 2 years ago and it still looks like it did the day I finished it.
  22. butch27
    butch27
    Dipper---That is pretty cheap. Did you buy it yet? Where is the LOCAL store?
  23. Dipper Jr
    Dipper Jr
    from Indiana
    Butch27,
    I haven't had a chance yet to go get the ABS I need to do my car. Hopefully this afternoon, so I can work on it over the weekend. Local store is in Lafayette Indiana... Called Meyer Plastics.
    Good luck.
  24. Is the FRP that Lowes/Home Depot sells, the same stuff as ABS?...
  25. butch27
    butch27
    I don't thing fb is the same as abs.
  26. butch27
    butch27
    I ment FRP. That's got to Be fibergl***.
