PLEASE DELETE!
Discussion in 'Cars For Sale' started by oddrod46, Sep 21, 2020.
  1. oddrod46
    oddrod46
    from Georgia
    City: Marietta Ga
    State: Georgia
    Price: 1940
    20200301_145256.jpg 20200422_080140.jpg 20200301_122232.jpg 20190902_194721.jpg
    1940 Ford Coupe traditional Hotrod
    Check this out!
    THE BOOTLEGGER
    1940 Ford standard
    Opera coupe.
    Traditional hotrod.
    This 40 has a timeless, old school look that was cool years ago ,and will not look dated in years to come! Upgrades were all done with quality and taste in mind.
    Built to be driven and enjoyed.
    Fresh rebuilt (with receipt) 59 AB Flathead V-8. 24 stud
    1946-48 59A block The block was vatted and Magnafluxed .100 overbore 8BA crank Egge 4 ring pistons Grant rings .20 main bearing .20 8ba type rod bearing Melling High volume oil pump Johnson adjustable lifters Winfield 3/4 cam Aluminum timing gear Solid valve guides Stainless valves Iskendarian valve Spring and retainer set Eurobond cam bearings Best Gasket set
    New Australian made Old Time speed Dual carb intake.
    Fresh built real Stromgberg carbs., jetted properly and synced.
    New Speedway Cal custom V- 8 aircleaners
    New Powermaster Powergen alternator.
    New Battery
    New air deflector panel
    New fuel pump
    New Edelbrock aluminum heads.
    New alternator belt
    New hoses upper and lower
    New Autolite sparkplugs
    New Moon fuelblock and pressure gauge
    New high flow Waterpumps
    New 180 high flow Thermostats.
    New Mooneyes plugwires
    New radiator overflow tank
    Crab claw distributor
    New Pertronix ignition
    New Pertronix ignitor coil
    New aluminum radiator and 2400 cfm fan.
    New 4 " drop axle
    New Firestone tires 5.50 and 7.00 whitewalls
    (Currently reversed to show blackwall)
    New 41 Ford hubcaps
    Restored original 40 Ford 16" wheels.
    New Dual Exhaust 1.75 front to rear
    New Reds headers.
    New disc front brakes/dual master cylinder
    New fuel tank New sending unit.
    New wheel bearings and axle seals
    New torque tube seals front and rear
    New rear panhard bar
    New tube shocks 4
    Freshly rebuilt steering box
    New Bluetooth stereo and speakers. (Hidden)
    New courtesy lights
    New bumpers 2 years ago
    New rear lowering shackles
    New complete custom roll and pleat, distressed interior.Including all new padding in seats, New headliner, New wind lace everything.
    Dash removed , restored, and repainted base clear black.
    New dash crome
    New dash knobs
    46 Ford Deluxe steering wheel restored.
    Rebuilt steering box
    Smoothed steering column Lime works signals switch.
    12 volt wiring
    Restored heater
    Working real Model Ahooga Horn.
    Fresh rebuilt 39 toploader(double detent) transmission.
    New synchros and Input shaft from Vanpelts
    Rebuilt to factory Ford clearences.
    New clutch
    New gl*** marble shift knob
    Very solid Georgia car with rust free factory floors, older base/clear paint that still shines nice and presents well. Far from perfect, not a show car body is straight but has its imperfections. just a good looking old Hotrod not a trailer queen or trophy *****.
    3:54 gears run 65+ reliably.
    Sounds great,Runs strong!
    Steers and stops as it should, and runs cool even on a 95 degree day.I have owned this car for over a year, and it is dependable and fun.
    PLEASE ASK YOUR WIFE FOR PERMISSION IF YOU NEED IT BEFORE CONTACTING ME.
    Let's s be respectful of each others time.
    Only traditional style Hotrods and Kustoms will be considered.
    Thank you
    Clean ***le in my name
    Atlanta,Ga
    (770) 402-8626
    -Brent-, GonzoMN, Nomadness and 7 others like this.
  2. oddrod46
    oddrod46
    from Georgia
    Thanks for the trade offers so far guys.
    pappatyrone likes this.
  3. oddrod46
    oddrod46
    from Georgia
    Please no latemodel trades.
    Not interested in modern cars.
    Thank you.
  4. oddrod46
    oddrod46
    from Georgia
    Screenshot_20201031-140935_Gallery.jpg Screenshot_20201031-140101_Gallery.jpg Screenshot_20201031-140056_Gallery.jpg Screenshot_20201031-140125_Gallery.jpg Screenshot_20201031-140050_Gallery.jpg Screenshot_20201031-140131_Gallery.jpg Screenshot_20201031-140139_Gallery.jpg Screenshot_20201031-140156_Gallery.jpg Screenshot_20201031-140226_Gallery.jpg Screenshot_20201031-140204_Gallery.jpg Screenshot_20201031-140307_Gallery.jpg Screenshot_20201031-140307_Gallery.jpg Screenshot_20201031-140204_Gallery.jpg Screenshot_20201031-140226_Gallery.jpg Screenshot_20201031-140131_Gallery.jpg Screenshot_20201031-140156_Gallery.jpg Screenshot_20201031-140056_Gallery.jpg
  5. oddrod46
    oddrod46
    from Georgia
  6. oddrod46
    oddrod46
    from Georgia
    Ttt
    Andy D likes this.
