please excuse my ignorance
Discussion in 'The Hokey Ass Message Board' started by brady1929, Jan 29, 2010.
  1. brady1929
    brady1929
    i am using 3/16 ths brake line for my project. 56 ford p/u front brakes and early bronco rear. i buy it from napa and the tag does not say. is this line 45 degree double flare? thanks
  2. V8Mongrel
    V8Mongrel
    from Apex, NC
    It won't be 37° AN type from a parts house, so it is one of the above.
  3. HOTRODPRIMER
    HOTRODPRIMER
    If it's brake line it's double flared. HRP
  4. brady1929
    brady1929
    sorry, just trying to verify that it is 45 degrees.
  5. V8Mongrel
    V8Mongrel
    from Apex, NC
    Not necessarily true. There is also 3/16" bubble flare available. That usually comes with metric fittings, but it is always best to check. IMO, brake lines aren't a place to be anything other than 100% sure it is right.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Bubble flair lines ARE metric,,10 mm,,close to 3/16 but not.HRP
  7. HOTRODPRIMER
    HOTRODPRIMER
    Yes they are. HRP
  8. Malibob
    Malibob
    from Pittsburgh
    Confirmed- They (Bubble Flairs) were mostly used on import vehicles like Healey's
  9. Bubble flares are also used on alot of late model GM cars and have been for a few years now.
  10. V8Mongrel
    V8Mongrel
    from Apex, NC
    I've got brake line in my garage that is labeled 3/16" and has bubble flares on it. That obviously doesn't preclude it from being 10mm just labeled 3/16", but nor does it preclude the original poster from having exactly what I have. When you buy the fittings for a bubble flare, they are listed as 3/16" or whatever size.
    Look up a Weatherhead SB312 or Plews 5312ST. US Thread (3/8"-24), 3/16" pipe, bubble flare.
    FWIW, I was the brakes product manager for one of the five largest distributors of autoparts in the country, not just some random guy on the internet. I don't say this to boast, just to point out that it was at one time my job to know such things.
  11. HOTRODPRIMER
    HOTRODPRIMER
    No problem with me,,the guy ask a question about brake lines and I answered his question to the best of my knowledge a early Bronco would not use metric fittings,,I would hope the counter man knows what the gentleman needs,,HRP
  12. nutajunka
    nutajunka
    By early I'll ***ume 60's or 70's will have a double flare. Just comparing it to your old one will tell you also, and if you don't have it just look at the wheel cylinder.
  13. hotrod32@usfamily.net
    from st paul
    there are No stupid questions just the ones you dont ask!!!!
