Technical Please Explain '54 Chevy Turn Signal Switch
Discussion in 'Traditional Hot Rods' started by Buzzman72, Mar 13, 2014.
  1. Buzzman72
    Buzzman72
    I've read most of the threads that have to do with building your own steering column for your rod, and I've asked for, and received, advice about adding turn signals. The consensus was to use the turn signal kit for the '54 Chevy pickup.
    I still don't understand how the turn signals cancel on this setup. Is there something that attaches to the back side of the steering wheel that protrudes into the switch ***embly to make the switch self-cancelling?
    Or are these signals manual-cancelling only?
    Thanks in advance for any help from someone who's BTDT.
    I'm looking to build a custom column for my '52 International rod project.
  2. squirrel
  3. Buzzman72
    Buzzman72
    Wasn't sure how the cancelling cam attached, or if it even had one. Thanks for the info.
  4. squirrel
  5. 325w
    325w
    I put one on a 55 pickup many years ago. Worked like a champ. 54 will have the cotton wrap wire. Switch is very much like a tri 5. If using a good used one for 12 v I wouldsolder on some new smaller wires. If still 6 v you'll need to replace with large wire.
