Please Help axle shaft info
Discussion in 'The Hokey Ass Message Board' started by mr37buick, Apr 10, 2013.
  1. mr37buick
    mr37buick
    from arkansas
    I have a 37 Buick it has an S10 rear end one of my axle shafts is bent ok i ordered a replacement for it well its 29 inches long and its too long 1/2 inch too long there fore my original one is 28 1/2 inches long 26 spline what did it come out of im really confused please help.
    Thank you
    Jose
  2. young'n'poor
    young'n'poor
    from Anoka. MN
    A and g body GM's had 28 1/2 inch axles, but I thought they were all 7.5 inch 10 bolts.
    Edit: I re read your post and notice you don't mention if its a 7.5 or 8.5 s10 rearend. I don't know for sure but if it's a 7.5 out of an early drum brake rear s10 it may have shared the g body's axle length.
  3. Mike51Merc
    Mike51Merc
    I'm not a GM differential expert, but do those rears have equal length shafts?
    Better to be too long than too short. You can have a machine shop shorten it.
  4. young'n'poor
    young'n'poor
    from Anoka. MN
    Some of them had equal length, others had different lengths side to side. There is many variations of these rears it's a bit of a pain in the**** if you don't know what it came out of.
  5. slider's house of kustoms
    from idaho
    4x4 s10 is wider than 2x4 s10 rear axles backing plate to backing plate, that might be your issue. Also; 82 s10 was a standard gm 10 bolt cut down.
  6. mr37buick
    mr37buick
    from arkansas
