Please Help DECODING VIN # 1963 1/2 Ford Galaxie
Discussion in 'The Hokey Ass Message Board' started by JoeCollectible, Oct 9, 2004.
  1. JoeCollectible
    JoeCollectible
    I have no idea how to decode the VIN # of my car. It is: 3U66C164740. Please Help me ASAP. [​IMG]
  2. shoebox72
    shoebox72
    Is this number off the plate in the door jamb OR the lip of the firewall next to the p*** side hood hinge?? The number next to the hood hinge is the actual VIN that you register the car with. the number on the plate in the door jamb is a warranty number.
    I can tell you tha it is a 63 galaxie 500 (notXL) 2 dr fastback that was ***embled in louisville plant. the last letter in the number you listed should be the engine code but there is no C code engine in 63.
    Write down ALL the numbers from the plate in the door jamb & the number on the firewall lip & I'll decode the whole car for you.
    Billy
  3. built in 1963 in Louisville KY, 2 dr fastback 289 2V Car #64,740
  4. Because its a 63 1/2 the codes for 1964 apply here.. the door tag will give you the rest of the info Colorr ,interior etc
  5. shoebox72
    shoebox72
    Marcus I know the 289 C code was available in 64 but I figured he copied the number wrong, like he put C when it's really a G [​IMG] [​IMG].
    Billy
  6. I knew that you knew about ya know.......hehehe.... I didnt even really read your replu until after I posted mine...If that was a G Code I would have told him it was a 289 and the offered to buy it!! [​IMG] [​IMG] [​IMG]
  7. JoeCollectible
    JoeCollectible
    Thank you all so much. Here is what I could make out of the # on the door itself. This number was located just above the VIN # that I already listed. Please note the gaps between #'s represent spaces.
    63B M66 06
    There appeared to be more but I couldn't read them. The hood hinge # matches the VIN on the ***le of car. This 63B # is color code maybe? Thanks again I love you all for this!
  8. 63B is the body style 2 dr fastback..M is the color code Silver Smoke Gray the rest is not right your missing a bunch of numbers.. Body Color Trim Date DSO Axle Trans
    63B M ? ? ? ? ?
    Vehicle Warranty number=VIN
  9. JoeCollectible
    JoeCollectible
    Oh man... thank you so much. (kneels down)
  10. JoeCollectible
    JoeCollectible
    Wait a minute... I am confused. {Had to edit.} I think I may be retarded or VIN challenged. So the car is M meaning wimbeldon white? Or is it silver like stated before.
    ok is this right? the # 3U66C164740
    3=1963
    U=Louisville
    66=Black/black Vinyl?
    C=289
    then what is the 164740?
    Someone said silver? wouldn't the M make it white? (off door plate?) - I dunno; total newb just learning about cars. I like the old cars because they are made of METAL!
  11. shoebox72
    shoebox72
    The M is white
    The 66 is 2 dr fastback coupe. Not black vynil.
    Billy
