Please help identify this Ford rear axle
Discussion in 'The Hokey Ass Message Board' started by blackjack, Oct 28, 2006.
  1. I bought what I was told was an 8.8" rear axle from a mid '80's Ford Mustang for my modified.
    I ordered up a Wilcap (7064) finned diff cover for it from the USA. Came to fit it today and it didn't. The diff cover is right for an 8.8 so I think that this axle isn't as described.
    I set out some pictures below. You will see that whilst the housing is the same hight as the 8.8 cover it is about an inch wider.
    I can't find any markings on the outside of the axle but stampled on the ring gear is;
    FORD USA D7AW 42" AA 17422
    The 7 could be a 3 as it is faint on the lower part.
    The axle is a ten bolt and the holes are 10 1/2" apart (from centre to centre) across the axle and 10" top to bottom. The axle is 49" wide between the backlng plates.
    Can you help identify this please - I'm wondering whether it is a 25 - 27 - 30 Dana??
  2. Burny
    Burny
  3. mrkerb
    mrkerb
    The "D" in the date code means that it is a 70's part. The second digit completes the year. If it reads D7 = 1977; D3 = 1973 etc
  4. So definitely not an 83 Mustang then.....
  5. born2late
    born2late
    looks like a 7.5 diff. PM me if you want to sell the 8.8 cover. I can use it.
  6. The37Kid
    The37Kid
    Is that a TT truck rear crossmember you're using? You may want to pull a few leaves out of that spring, looks a bit to stiff to me. :)
  7. It is indeed - I was thinking of pulling a couple of leaves AND fitting PTFE tape between the remaining ones as well as polishing & chamfering them.
  8. dezaster
    dezaster
    from u.k.
    is it not an 8"? it looks like the one on the back of my '60 falcon, with the tapers on the ends of the tubes. i beleive they ran quite late on the compacts.
    but then again, i know **** about this kinda thing :eek:
  9. 83 Mustangs didn't have 8.8's. and 7.5's did not arrive until 1979. The D7 as others stated means 1977 so my guess is it is a 7 1/4 axle from a Pinto or a 6 cyl Maverick of that vintage. This would be the same axle as non V8 60's Falcons and Mustangs. I'm not sure but the 7 1/4 may have the same pan bolt pattern as the 7.5 but I can't say for certain. Stu
  10. Ford 8" and 9" don't have a cover, they are non-integral carrier axles (pumpkin style) Stu
  11. dezaster
    dezaster
    from u.k.
    thanks for the info, i know the axle looks the same as mine, and i had been (mis!) informed mine was an 8" in the past :)
  12. BTTT - Anyone recognise this axle?? More accurate measurements (bolt centre to bolt centre) are;
    10- 6/10" (or 268mm) ACROSS
    9- 15/16" (or 254mm) TOP TO BOTTOM
    It's definitely a Ford as this is stamped on the pinion. It's 10 bolt.
    It was brought over from the USA by a UK hot rod parts dealer and he still thinks a came from an 80's Mustang of some sort.
  13. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Mustangs used 7.5's till around '85, then went to 8.8 because they were tired of the warranty problems ***ociated with torquey smallblocks and leadfeet....Probably the 7.5
  14. squirrel
    what is the diameter of the crown (ring) gear in inches? that is what axle it is....pretty simple
    D7AW would be a 1977 design.
    (I'm guessing 6-3/4", as used in the pinto/mustang II type cars)
  15. TrailerTrash
    TrailerTrash
    I have the same axle in my car... exact measurements you describe with the necked down axle tubes. Mine is a Ford 8.8 from a 91 Crown Victoria. I'm sure of this because I just installed a new ring & pinion and posi unit for the 8.8. The finned cover in your photo looks like a GM 10 bolt to me?
  16. TrailerTrash
    TrailerTrash
    Thats good advice from Squirel !! For the 8.8 axle the ring gear will measure aprox. 8 3/4 eyeball using a tape measure. If the ring gear measures 8 3/4 (and I think it will) I'd be calling USA about the cover.
