Hot Rods Please help me identify MCs
Discussion in 'The Hokey Ass Message Board' started by ArtGeco, Sep 22, 2024.
  1. ArtGeco
    ArtGeco
    from Miami
    Im working on a 32 ford coupe with dual master cylinders.
    Im trying to find rebuild kits, but I can't
    make out the part numbers completely. also, it seems that the
    bolt holes are an odd spacing (It seems).
    Also, I don't see any online with circular extrusion on the sides
    They are stamper FoMoCo
    Specs:
    Bore Diam 1"
    Bore Depth (If I'm measuring correctly?) 4.5"
    Horizontal mounting bolt distance center to center
    Vertical mounting bolt distance center to center
    Part numbers appear to start with AA 21???
  2. alchemy
    alchemy
    My off the cuff guess is 55-ish Chevy.
  3. ArtGeco
    ArtGeco
    from Miami
    Sorry, should have mentioned, They are stamper FoMoCo
    I edited original post with that info.
  4. BJR
    BJR
    1956 Ford.
    warhorseracing likes this.
  5. squirrel
    57-60 Ford truck. They used a hydraulic clutch
    choffman41 likes this.
  6. In the '60's, every '57-60 F100 in the junkyards was missing the pedals and cylinders.
  7. Fortunateson
    Fortunateson
    Educate me... a pair of MCs, one for front and back brakes or one for brakes and the other for clutch? Before dual MC s?
  8. squirrel
    One is brake, the other is clutch.
  9. RICH B
    RICH B
    If the bores are good and you get regular '52-'59 Ford car kits to rebuild them; remember to leave the residual valve out of the clutch m/c.
  10. ArtGeco
    ArtGeco
    from Miami
    Thank you for that, I would have made that mistake.
