Please help me start my car :(
Discussion in 'The Hokey Ass Message Board' started by whitewallslick, Mar 14, 2007.
  1. whitewallslick
    whitewallslick
    Our daily driver '96 Buick Century was stolen tonight. The car was recovered a mile from my house with the column ripped apart. Had to drag the family out a few minutes ago to claim the car. I tried to start it with a screwdriver by sliding the metal bar with the teeth on it toward me, but the car just clicks like it has a dead battery, which it doesn't. Does anyone know how the the hell to start the thing? I need to get it home so I can fix it asap.
    Thanks,
    Eric
  2. scottybaccus
    scottybaccus
    If it's like the earlier GMs I know, the bar with teeth on it should push a rod down the column, toward the firewall. That may have changed. if you pull the cover off the column and find the actual ignition switch by following the harness, you should be able to remove it and operate it by hand. Repairing a column can get expensive. You probably want to look for a salvage unit. Good luck.
  3. brandon
    brandon
    have you looked under the car and under the hood.....? a lot can happen in a mile....especially when your drive it like you stole it...would tell ya to tun the column to the run position and jump the starter....but on those rides .....that may be impossible....good luck ....hope all turns out well....brandon
  4. Don Moyer
    Don Moyer
    Can you turn the wheel? Is the ignition turning on, are the lights in the dash on? If so, just jump out the starter with a $7 remote starter available from any part store. People get nervous when working on newer cars. It is just a car. Think basics.
  5. belair
    belair
    Did the key have one of those chips in it?
  6. 53sled
    53sled
    from KCMO
    neutral safety interupting the fun? maybe built in anti theft took its time to work? There was a string of about 20 gm column equipped cars being broken into around KC. With the column busted and ready to drive off the thieves either drove it 20 ft or just left it. Weird
  7. if the car had a p***lock chip. it would start and die. it really sounds like it needs a jump start. it coulda been sitting around with the doors open or the interior light on all night. the battery could just be weakened. try jumping it, and see if that gets it going.
  8. cadillac dave
    cadillac dave
    put a volt meter on the battery and see how many volts you have. if you are low jump it. sure sounds like a week battery. cadillac dave
