i just picked up a 1927 ford rolling chasis. the only thing its missing is the brakes in the front . It has the spindles and drums but thats it . i did a search to see if i can try and use model a stuff of convert it to the later f 100 brakes but came up empty . Is ther a huge difference from the T to A spindles ?? any help would be appreciated... thanks zach
Model T axles and spindles are completely different from Model A. Yours isn't missing the front brakes...they never had them to begin with.
Should've passed on the T frame and got an A frame at the very least... unless you're making a period correct hot rod to the tune of the 20s?
