Projects Please ID These two Transmissions (1947 Chevrolet Project)
Discussion in 'The Hokey Ass Message Board' started by Aeroman, Dec 27, 2013.
  1. Aeroman
    Aeroman
    Hey Fellas,
    I posted these images previously but got the thread deleted (I posted in the wrong section, my bad). I believe I got what I needed thanks to the members that responded. I am interested in a transmission for my '47 Chevrolet Fleetline project. I will be using a 261cui with a '68 Chevelle rear end (3.08 gears). I would like to retain the 3 speed column shifter and use full synchro. I believe the second image is a Saginaw transmission, late 60s/early 70s, which I may go with (full synchro?). The first appears to be a mid to late 50s truck transmission? If you guys can chime in, I would appreciate it. Thanks again.
  2. squirrel
    that's right....the one on the right is full synchro.
  3. Aeroman
    Aeroman
    Great. Thanks!
  4. 302GMC
    302GMC
    from Idaho
    Hunt up a '49-'52 3 speed car for the shift linkage. '48 & earlier is for selector & won't do the job.
  5. Aeroman
    Aeroman
    Thanks 302. You're the third person to recommend that. I'll go search for one, thanks
