Technical Please post up some interior photos of model A-s with Muncie or T-10 trans
Discussion in 'The Hokey Ass Message Board' started by Choppedcoupe, Jul 23, 2018.
  1. Choppedcoupe
    Choppedcoupe
    Just got a T10 in a package purchase with a sbc. Engine is going into my 31 Ford coupe. Worried about shifter placement fighting the bench seat. Anybody got pics to re***ure me?
  2. mgtstumpy
    mgtstumpy
    There are different shifter mounting points and extension housings?
    lothiandon1940 and hendelec like this.
  3. F&J
    F&J
    a 55-57 Chevy 4sp Hurst shifter picture would show you how it clears the stock bench in those years. The stick does not come straight up where the shift body is, it goes forward a lot, then goes upwards.
    Torkwrench and Just Gary like this.
  4. missysdad1
    missysdad1
    Not enough information. But you can still figure it out. Measure your ***embled engine (including water pump and fan) to get the length from fan to shifter. Then measure your car from the radiator back to the seat. Compare the two measurements, adding fan clearance as required.
    If you are running a Deuce frame you're in good shape, but things get really tight if the frame is stock Model A. With a Model A frame you'll have to cut the firewall to get the engine in and that will put the shifter somewhere under the stock bench seat.
    The solution in my opinion would be to remove the stock flooring beneath the stock bench seat and replace it with 3/4" marine plywood after moving the subrail crossmember back as required for shifter clearance. Then invest in a good aftermarket seat - not a minivan seat - which you can mount to the new floor in a rearward position to give you lower seating and better legroom.
    Yes, this requires more changes than you probably anticipated but it is the right way in my humble opinion. Here's how it mocked up in my new roadster project, but keep in mind that my car uses a Deuce frame so the engine does not intrude into the footwell area. Good luck with yours!
    B Bay Barn and hendelec like this.
  5. Calcutta Baits
    Calcutta Baits
  6. Calcutta Baits
    Calcutta Baits
    Sorry about that, don't think this was your question. I do have a Super T10 but in different vehicle.
  7. DDDenny
    Richmond T-10 in my roadster.
    Not a model A but creativity and a welder is your friend, and not just the seat that can be an issue, getting the handle away from the drivers leg requires some effort too.
    This was one of the Hurst handles that has a long side offset, shortened the offset, perfect.
    hendelec likes this.
  8. wuga
    wuga
    I used the offset handle as well in my 30 A to get the handle away from my leg.
    Part # 3916790
    Warren
  9. sdluck
    sdluck
    I will try and get pictures.I am putting A T 10 in my 1929 model A,I bought a rail type shifter that mounts to the top of my t-10 shifter comes out in stock model a position. I don't remember the name,but there are picture on the hamb somewhere.
  10. Ed Angel
    Ed Angel
    Pics of what I did to a Muncie to get it to fit in my 30 roadster . IMG_6224.JPG IMG_6237.JPG
    hendelec and GordonC like this.
  11. Ed Angel
    Ed Angel
    I’ll get some pics of the interior today if you like . I didn’t end up running the Tri 5 shifter . I bent up another shifter that works great . Second summer driving it , shifts awesome .
  12. Choppedcoupe
    Choppedcoupe
    Thanks, gents! Keep pics coming. Very helpful.
  13. lo c dan
    lo c dan
  14. sdluck
    sdluck
    Did you see my post about T&F Shifter?
  15. sdluck
    sdluck
    31799 Chestnut lane Lebanon OR 97355
  16. sdluck
    sdluck
