Technical Pleats
Discussion in 'Traditional Customs' started by The Chevy Pope, Jun 25, 2024.
  1. Gearing up to do the seats on my 53 and stuck between 1" or 2" pleats. Want to eventually do tuck and roll but not at this point. Which would be more era correct for 1960ish on pleat width? Kinda leaning towards 2" but worried considering I grew up in the 80s and 90s I was worried it was more of a later look lol
    Sharpone and lothiandon1940 like this.
  2. lothiandon1940
    lothiandon1940
    Just me, but 1 inch pleats look too busy.
  3. Bandit Billy
    Bandit Billy
    Here's a pic of 1" and 2" on the same seat for comparison. I think the 1"er's are a bit tight.
    pbr40, firstinsteele, GordonC and 4 others like this.
  4. lothiandon1940
    lothiandon1940
    2 inch pleats in my '40, 2and 1/2 in the '32. 241545053_4627636003921916_3492956903589952085_n.jpg 241455029_4627635877255262_7998702223915004630_n.jpg thumbnail (33).jpg 241392874_4627635840588599_8261593297351803768_n.jpg 20240625_151712.jpg thumbnail (16).jpg thumbnail (18).jpg
  5. Ok I was preferring the 2" so at least I don't have to worry about them fitting the disco era lol
  6. Bandit Billy
    Bandit Billy
    2" in my wife's 41 PU
    And 2" in my 34 roadster
  7. I AM going to try to do them in a way they have a more bubbly tuck and roll feel. Going to stuff them with 2" wide half inch thick strips cut to width
  8. Bandit Billy
    Bandit Billy
    "I like what they've done to my interior"
  9. lothiandon1940
    lothiandon1940
    ...What! No Corinthian Leather?! 69243114_2468339023381113_5755506169506430976_n.png
    X-cpe, Bandit Billy, alanp561 and 3 others like this.
  10. snoc653
    snoc653
    from Iowa
    2 inch is the way to go imho. I thought the way to do it was to take a backing cloth, lay the appropriate thickness of foam on top of it, cut the pattern you want partially into the foam (1/2" deep for a 3/4 or 1" deep pad) then sew the top fabric to the bottom down the cut lines. Always had a little extra top layer as you'll loose a little material width due to the depth. But there are people that know interiors that can correct me. It would be a royal pain to stuff foam down the length of the pleat.
    Tow Truck Tom and The Chevy Pope like this.
  11. That's the plan. Basically going to lay the first s***ch, put a strip of foam next to first s***ch, pull material snug and s***ch other side of foam and repeat till done
    lothiandon1940 and Tow Truck Tom like this.
  12. Ended up with a 1974 singer sewing machine with table lol
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    1 1/2" inch pleats are for customs. 2 inch pleats are for street rods. all of my cars have 1 1/2 " pleats and the 56 and the 55 were both done in the early sixties. And you don't use strips of foam. you buy the channeled foam that is made for sewing pleats. It has grooves in it every 1 1/2"
  14. See that's why I asked. I know a 70s Ford I'm restoring to original for my boss has flat 2" pleats. So that's what had me wondering if it was more of a later thing
  15. K13
    K13
    I have never seen any upholsterer use anything but scrim backed or sew foam for making pleats. There are no channels cut in it just a fabric backing to hold the s***ches. I did a ton of research before doing my interior and never saw what you are mentioning. Originally guys would individually stuff pleats by sewing the top material to a fabric backing and stuffing the pocket between the two.
    alanp561 and jaracer like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    https://www.miamicorp.com/buy/produ...romProduct=CLENC81a3ad83b92621d4&type=similar
    poncho catalina likes this.
  17. lothiandon1940
    lothiandon1940
    back up for further consideration
  18. Just Gary
    Just Gary
    Those are BEAUTIFUL. :cool:
    lothiandon1940 and Moriarity like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    the Car Craft dream rod and the Futurian have 1 1/2” pleats while the Outlaw has 1”. All done with channeled foam
  20. dana barlow
    dana barlow
    from Miami Fla.
    Late 1950's, Newts Upholstery an Boat Tops,27 Ave. Coconut Grove, Florida.
    He kept in stock pre formed/molded pleats vinyl in a number of colors.
    It was a bit lower $ then doing them by sewing ,plus on boats more water proof too.
    The molded pleats were 1.5 inch wide ,it's still made,an I've used same when redoing my hotrod as well.
    Sure sewed pleats are cool,but the molded was used a lot.an on my low $;),was just super cool :cool:to have nice upholstery.
    This was ture for lots of mid an low $ hotrods an customs.
    I worked part time after school;as clean up n odd job n gofor at Newts.
    It how I got my upholstery done in my hot rod and then my custom.
    I did a lot of indoor cars shows,and for pleats,it was about 1/2 an 1/2 sewed or molded.
    I still have 1.5 inch molded pleats.:D:cool:,had to update my steering wheel some years back,when it's plastic outer grip started falling apart,so added new one with wood to match other wood trim:p in my 28A. 021.JPG
  21. Any links to find it?
    dana barlow likes this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    1 1/2” pleats in my Corvette IMG_9006.jpeg IMG_9020.jpeg IMG_8239.jpeg IMG_5554.jpeg
  23. Moriarity
    Moriarity
    SUPER MODERATOR
  24. Just Gary
    Just Gary
    Pleats in the early '60's were kinda busy.
    Doyle Gammel coupe & Kendrick's Super Prune look like 1":
    Whereas the Avenger (show car) looks like 1.5-2":
  25. dana barlow
    dana barlow
    from Miami Fla.
    alanp561, Just Gary, Speccie and 2 others like this.
  26. SS327
    SS327
    Didn’t the Beatles have a song “Please pleats me”?
  27. jimmy six
    jimmy six
    2” work for me….remember the package tray if you have one and you want 50-60’s look.
    This may sound trivial but if your doing verticle pleats or tuck and roll make sure you tell the upholstery shop and the person doing the sewing …the pleats on the back MUST LINE UP with the pleats on the seat…nothing looks as unprofessional as missaligned custom upholstery work. This goes for horizontal too if they are inserts……If it doesn’t…. It’s all you will see every time you get in your car mark my words..
  28. On the 54 I'm actually going to do ****. Did that on a custom built 57 Ford custom model car I did in 1/25 scale and loved it. Not sure if I'll do pleats on the package tray of the 53. Will really have to see how it looks when I do the seats. Not a big deal to go back and redo the tray though
  29. unfinished
    unfinished
    I copied a mid sixties Pontiac bucket seat design in my coupe with diagonal pleats. Pardon the white and black under construction,but I went with varied pleat width. I've used the channeled foam and it's easier to get the more pronounced pleats.
    The Chevy Pope likes this.
  30. Yeah I'm shooting for really bubbly pleats. I look into channelled foam
