Plug on sump Gen 1 5.7 litre(350)
Discussion in 'The Hokey Ass Message Board' started by hudson48, Jun 12, 2013.
  1. hudson48
    hudson48
    Attached is a picture of a fitting on the RHS of the sump on a Chev 350.
    it looks like it has an electrical plug in it but in my car is not connected.
    Anyone know what this is for?It is weeping oil and if the full unit is not needed I may replace it with just a plug?Maybe it is connected to something in the sump?
  2. fastcar1953
    fastcar1953
    knock sensor is my guess. if not using just plug it.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    more than likely a low oil level switch.
  4. hudson48
    hudson48
    I think that is right.Checked with my auto electrician and he said oil warning light(which I don't have or need). I have a separate connection for an oil pressure gauge.
  5. burtrido
    burtrido
    is that a ls1? (Gen 3) If so I will have a look at mine tonight. What's the motor from? or is it a crate engine?
    Cheers
    Gene
  6. hudson48
    hudson48
    Yes I meant Gen 3.It is from a Holden (GM Australia) SS 2002 model.
  7. burtrido
    burtrido
    Ok. I'm Playing with a 2001 ls1 at the moment.
  8. burtrido
    burtrido
    I had a look at mine just now. I don't even have a place for a plug like that. It won't be a knock sensor, they are under the intake. The reluktor wheel sensor is up higher behind the starter so its not that, my guess is it's some sort of oil level sensor. I hope this helps. What's this engine in now?
  9. DoubleJ52
    DoubleJ52
    from Belton, MO
    It is a low oil level sensor.
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    My car has that and although it isn't a Chevy (Cadillac) it is a low oil warning sensor. Not a bad feature to have, but you can just not use it if you want.
    Don
  11. hudson48
    hudson48
    It is in the Hudson.
