Hot Rods Plug weld over por15?
Discussion in 'The Hokey Ass Message Board' started by old_chevy, Apr 15, 2025.
  1. 05snopro440
    05snopro440
    The undercoating will most likely burn off. The problem is where the remnants go. Likely some of it ends up in the welds and a long the weld boundaries, and that's how you get weld defects. Letting the undercoat burn off in the welds is lazy and can bite you later if those welds crack because of it.
    Metallurgically speaking, it's a bad idea.
  2. alchemy
    alchemy
    Sounds like the work they’re doing isn’t very professional either.
    GuyW likes this.
  3. 05snopro440
    05snopro440
    To be fair, he didn't say how much he was paying them.
    caprockfabshop and Bandit Billy like this.
  4. GuyW
    GuyW
    It sounds like the start of another "half-wit Butchery" thread...
  5. cfmvw
    cfmvw
    Welding is like painting: how well you clean and prep the part will show in the final product. I used to work with a guy who mostly ran his mouth to make up for poor skillsets/knowledge. Refused to clean and prep anything he welded (no beveling, burn through paint, rust, grease, scale, ect), then blamed "junk" equipment for the poor results. Just about everything he made failed for one reason or another.
    mad mikey and 05snopro440 like this.
  6. old_chevy
    old_chevy
    from USA
    QUOTE="05snopro440, post: 15562314, member: 144657"]To be fair, he didn't say how much he was paying them.[/QUOTE] Paying by the hour. Over $100/hr.
  7. patterg2003
    patterg2003
    RMONTY and Stock Racer like this.
  8. 05snopro440
    05snopro440
    Over $100/hr for them to tell you stuff like this is fine? Yeah... Not cool. I'd have a hard time trusting their work.
    mad mikey likes this.
  9. mad mikey
    mad mikey
    Por 15 can not be welded over! THE END. Have it done correctly or don't. DAMN!
    Bandit Billy likes this.
  10. old_chevy
    old_chevy
    from USA
    How difficult is it to remove the undercoating for welding? How is it removed?
  11. 05snopro440
    05snopro440
    Best to Google it. There are a lot of different ways to do it, doesn't need to be rehashed.
  12. alchemy
    alchemy
    Grind it, desolve it with lacquer thinner, s****e it then hand sand. Try and see what works best for you. Kinda simple really. Have you ever tried removing paint before?
  13. RMONTY
    RMONTY
    Flap disk, grinding disc, sometimes you can just s****e and peel, depending on how long it's been on there. Just use an old flap disc or grinding disc because that stuff can sure gum up and ruin a new one.
    Although I've never heard of it being discussed, I can see it causing a grinding disc to explode like gumming one up with aluminum? That is purely speculation on my part. Probably overkill but better safe than sorry.
  14. Bandit Billy
    Bandit Billy
    Just because a shop charges you for their services does not make them professionals.
    There are people with jobs,
    people with careers and
    finally, people that are professionals.
    The workers the OP is referring to I would land firmly in the first category and the very reason the majority of us do our own work. If you don't know how to weld and clean metal and you don't have the time or facility to learn you end up at the mercies of these folks. You have an advantage in that you have the HAMB and some excellent advice on how to proceed by members that have done this before. Heed their warnings and listen to their instructions. They are not being paid, they are offering ***istance with nothing to gain.
    Jim Bouchard and mad mikey like this.
  15. alchemy
    alchemy
    Think of it this way: if the surface isn’t clean enough for you to feel comfortable laying your sandwich on it between bites, it might be too dirty to weld.
    05snopro440 and RMONTY like this.
  16. old_chevy
    old_chevy
    from USA
    Most people I think just care if the paint is shiny. I need to work with the shop and try to fix these problems. I'm not sure how to best approach the shop. I'm at the mercy of the shop. Things I've asked to have done were not done and it is too late to fix. I'm not expecting a high end restoration. I realize that some short cuts will need to be made. At the end if the weld is strong and corrosion resistant that is what matters.
  17. alchemy
    alchemy
    Short cuts should only be made if that’s what you are paying for. You should get what the contract specifies.
    05snopro440 likes this.
  18. RMONTY
    RMONTY
    If they are doing a piss poor job, get that car out of there! I have no idea about your car or situation but if you are already questioning what and how they are or aren't doing a good job, you are only at their mercy if you leave the car there. Just my opinion, as I stated I know nothing other than you saying you are at the mercy of a shop that already hasn't done what you asked of them. I will go back to being "it's none of my business" now....
  19. K13
    K13
    You are asking an awful lot of questions here on multiple threads. If you are not happy with the shop pull your car out and take it else where. I can guarantee one thing if you start questioning everything they are doing, which it seems like you might doing be based on all your threads, the work will only get worse as they tire of you questioning everything they do. If they are doing shoddy work you going in and saying a bunch of people on the internet told you they are not doing things right is NOT going to improve the situation.
  20. lostone
    lostone
    from kansas
    I agree, pull the car out of the shop, take it home, do some research both on repairs performed and other shops in the area.
    Once you do all of that then start looking at other cars the shop you researched fixed to see if your happy with that work along with the customers thoughts on that work then talk to the shop, tell them what you want, what you expect and then let them start on your car OR start researching another shop until you find one that does repairs to your satisfaction...
    Your money... your choice....
  21. old chevy
    old chevy
    For the record this is not me asking these questions.
    swade41 likes this.
  22. Bandit Billy
    Bandit Billy
    And that is the point of my response. Being at the mercy of the shop is a tough position for you. High end restoration is not the point, quality repair is. It is your money, it is your car, make the best decisions you can.
    05snopro440 and mad mikey like this.
