Plumbing a combination/proportioning valve
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Feb 7, 2008.
  1. Hellfish
    Hellfish
    I have a universal "GM style" disk-drum combination valve (includes a proportioning valve), like the one MP Brakes sells and I'm not sure about plumbing it. I know what goes where, but I'm not sure about the SIZE of the lines. One site (that I can't find now) said that all lines had to be 1/4", which seems too big. My brake cylinders and hoses are all 3/16". Can I use adapters and use 3/16 like everywhere else? Or do I need to use large lines to the valve, and adapters stepping it down to 3/16 after the valve?
    Yes, I have a 10# residual valve for the rear and a 2# residual valve for the front disks, in case you were going to ask. This is for my Econoline, if that matters.
  2. flat-bill
    flat-bill
    There is no reason to use one size line over another. Use what fits in the holes.
  3. Motorbreath
    Motorbreath
    flat-bill wouldnt larger lines reduce pressure? I know a roundy round catalog
    I have sells larger lines for this purpose.
  4. rstanberry
    rstanberry
    from terrell tx
    I used all 3/16 , works like a hose
    Ron
