PLYDO disk brake conversion?? Mopar guys?
Discussion in 'The Hokey Ass Message Board' started by fatluckys, Oct 7, 2004.
  1. fatluckys
    fatluckys
    Anybody done the Plydo disk brake conversion? My new 50 Dodge project came with everything except the calipers and hoses. I called Plydo- they wouldn't tell me what calipers I need, but they will sell them to me for $200. Seems a little steep. So... anybody know what calipers I need to use?
  2. moondisc
    moondisc
    I'm not 100% certain, but I think they use GM calipers.
    At least the kit that was in my buds 39 Dodge did.
  3. Justin415
    Justin415
    So do you have a modified backing plate or an aftermarket caliper bracket? Whats the rotor size and width? If you can get a pic of the setup I'll tell ya. Or measure the distance between the caliper mounting holes, center to center for a clue. There are a couple different ways to disc mopar.
  4. fatluckys
    fatluckys
    It's an aftermarket bracket. Caliper mounting holes are 5 7/16 center to center. The rotor is 11"across x 1" thick. Here's a pic-
  5. moondisc
    moondisc
    Looks like the same bracket on my buds 39.
    His had Camaro calipers on it.
    It's GM for sure.
    Might be a later metric caliper.
    Take the bracket to the parts store and match it up.
  6. JimC
    JimC
    from W.C.,Mo.
    Talk to HotRodHon.
    The ply I got form him has Camaro rotors and Corvette calipers
  7. FeO2
    FeO2
    My guess is GM metric midsize car. (Monte Carlo "80 & up)Tell me if I win the prize.......
  8. fatluckys
    fatluckys
    [ QUOTE ]
    [/ QUOTE ]
    I'm hoping I can figure this out before I have to deal with the idiots at the parts store. [​IMG]
  9. dehudso
    dehudso
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Amen on that one.
    You guys have a NAPA around? Those guys usually kick ***.
    How thick is that adapter plate?
  10. 50dodge4x4
    50dodge4x4
    We put that setup on my sons 47 last year.
    Calipers 78-82 (?) GM intermediate (monty, Cutl***, Regal, Malibue) used brake hose from same car.
    Rotors depend on the bolt pattern. 4.5 = Ply Vollari
    4.75 = Camero
    Gene
  11. Justin415
    Justin415
    It's a GM metric (mid size) single piston. And I'm guesing the rotor width is actually .875". The earlier "big" Piston calipers (70-77 cmro) have a 7" mounting spread. try looking up the part # on 82-94 Camaro/Firebird caliper for interchange and bring a ruler to measure the mounting holes. These should be the floating calipers you need. I can check the part # when I get home, I have the same calipers in the box you need(I'm usin em).
  12. fatluckys
    fatluckys
    Thanks everybody!!
    The rotors are definitely 1" thick. They are stamped .940 min. thick. Looks like a Volare bolt pattern.
  13. Crease
    Crease
    Fatluckys,
    I ran into a similar situation on my 40'. I needed a replacement master cylinder, but the company wanted a fortune for it. I called back and asked them for a rebuild kit. The guy gave me the number to take to the parts house. I cross refrenced that to the master. Maybe you could work a similar angle? Tell them you need shoes maybe? It's not lying it's just budget procurement.
  14. fatluckys
    fatluckys
    That's pretty sneaky Crease. I'll have to remember that. I checked Autozone.com for prices on GM metric calipers- looks like I can get calipers, pads, and hoses for $75-105 depending on how much I want to spend on the pads. That's a little easier on the budget than the $200 I was quoted earlier.
  15. Crease
    Crease
    Not as sneaky a charging $200 for a $30 dollar master cylinder. [​IMG]
    Let me know how those brakes work out. I may put a set on the 40'.
  16. LOUDpipes
    LOUDpipes
    from Finland
    I´ve got one installed in my 46 buz coupe. Rotors: ply volare/ dodge aspen. Calipers: Camaro from 80- smthing. Caliper bolts: ELDORADO from 70 smthing (front wheel drive?) This is important at least was in my set, because if the Camaro bolts were used you could only use one third of the brake pads....and then have an interfierence problem....It was more than ten years ago I installed it and had to call them at PlyDo to figure out the bolt problem. Maybe it is solved nowdays in improved design of the bracket....
    Good luck
  17. Justin415
    Justin415
    Sorry I cant find those boxes with part#. But it sounds like you got all the info(sneaky) you need. Good luck.
  18. Daddiojoe
    Daddiojoe
    from Austin, TX
    Hey! I just picked up a '50 Plymouth P-19 Tudor and need more info on this PlyDo stuff. Is this a straight ahead disc brake conversion using the suspension that's already there?
    Any help would be appreciated,
    Joe
  19. George
    George
    I got the kit for my '47 Dodge from them about 5 yrs ago. Didn't fit. Called them up & they said they probably sent the wrong one. 3 weeks (or so) later I called them back, like, where is it? tThey seemed suprised! Why didn't they send it when I first called?:mad: I think Mr. Street Rod has a kit also.
  20. George
    George
    Yes it replaces the backing plate & brake stuff. If I remember right you have to drill out the 2 bolt holes in the steering arms, where they are parelell it is best done with the proper equipment. You get (depending on what you order)a mounting plate & hub/spindle adaptors the instructions tell what calipers & rotors to use. They have a rack & pinion steering (Sunbird) kit. Mr. Street Rod has a shock relocation kit.
  21. 55 dude
    55 dude
    rise up fellow mopar dudes! are you guys saying that ply-do "****s" in the customer service dept? that kind of at***ude will put you out of business quick. hope someone is listening. personally i think the ******** on the master cylinder would steer me away from their doors all together. scarebird, are you reading this? sounds like the 39-4? mopar guys need some loyalty.
  22. Alienbaby17
    Alienbaby17
    I'll say PLYDO ****s in that regard.
    I ordered their catalog a few years ago- when it didn't show up after several months I called them and they said they were getting them printed. ANother several months later it finally showed- half the pages in it were duplicates of the others inside- I was very unimpressed and it looked very amateurish.
    I have a 1950 Dodge 1/2 ton truck that I converted to disc brakes. I ordered my parts through AAJ Brakes (on the web- do a Google search if interested- I can't remember the address) and they were very friendly- parts fit, good prices. They even sent me a Christmas card!:D
    I think Plydo seems to think they have the market cornered on Mopar stuff so I think they think they can charge whatever they want and treat customers however they want. Prices seemed high for most of their things to me.
    Jay
  23. <TABLE id=HB_Mail_Container height="100&#37;" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off"> I've dealt with Ply-Do several times. I bought the disc brake conversion kit for my '39 Ply Coupe and some other stuff. Also, there was a bunch of extra parts and some receipts for things that the previous owner bought from them for the car. Their prices are insanely high, their service is not very good, they act like they're doing you a favor selling you stuff - you be the judge.
    I'd only use them as a last resort because they ****.
    </TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
    </TD></TR></TBODY></TABLE>
  24. smalltownspeed
    smalltownspeed
    Ill agree with that. Ive had a few early mopars, and have done business with them a few times, but only as a last resort. Always try NAPA first. The guys ta PLYDO are ****he@ds, I dont think Ive met many old car guys that were half as rude as they are. But hey, they do have some of the harder to find parts....
    55 Dude- Why are would you give your loyalty to somebody who is a complete *** and makes you grab your ankles every chance they get too?
  25. 37hotrod
    37hotrod
    I haven't looked at one of Ply-Do's catalogs in years. What struck me was that every part I looked at seemed to be from some other manufacturer (such as Steele Rubber company), right down to the catalog descriptions. I don't think they make anything of their own, except customer service blunders!
  26. NoWifeCrissis likes this.
  27. 4woody
    4woody
    "Olddaddy" here on the HAMB makes & sells his own disc adapter kits for old Mopars. I used his on my 38 Chrysler and it went smoothly. Comes with a full parts list specifically so you can buy the standard stuff locally.
    I think he is also doing shock relocation and R&P conversion kits too.
  28. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    Yep. I am working on one now. Since the hub has tapered bearings, we plan on reusing it - and the rotor/caliper combo will fit inside the stock 15" rim. Stay tuned.
  29. Daddiojoe
    Daddiojoe
    from Austin, TX
    Did anybody ever come up w/ the master cylinder number/application?
  30. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    Got the blanks in today - need to machine the bolts and weld up he blanks and see how it works. Ended up using the Volare rotor and pin type Mopar caliper. Will have pix when done.
