plymouth flathead electronic ignition
Discussion in 'The Hokey Ass Message Board' started by phukinartie, Oct 9, 2008.
  1. phukinartie
    phukinartie
    Haaaaaalp!!!! does anyone know if there is an aftermarket electronic ignition foe a plymouth flattie any ideas will help!
    thanks
  2. Archie
    Archie
  3. Specialdeluxe
    Specialdeluxe
  4. phukinartie
    phukinartie
    thank you!!!!!!!!!
  5. 4woody
    4woody
    Check with "Mart" here on the Hamb. He makes a box that lets you use your points in the original dizzy just as a trigger. Don't know what result you are after, but this takes the points out of the load carrying business to make conventional ignition more reliable.
  6. plym_46
    plym_46
    from central NY
    You can also adapt the electronic ignition by mopar using the Slant Distributor with that set up. You need to do a bit of machining on the dist and change the drive tang. also need to run 12v Neg ground.
  7. d2_willys
    d2_willys
    from Kansas
    Check Pertronix, they are suppose to have electronic ignitions for 6V systems.
  8. Bullington
    Bullington
    They have 6V for Volkswagen only. Spent an hour on the phone with them.
  9. plym_46
    plym_46
    from central NY
    Pertronix has one for a M***ey Harris combine engine Chrysler block same dist. and the catalog says its availabel in 6V +.
  10. PatrickG
    PatrickG
    ive got tom langdons unit too. pretty satisfied
  11. hkestes
    hkestes
    Ditto for me. No problems with my Langdon's.
  12. Bullington
    Bullington
    Good to know.
    I just ordered
    Petronix #1561P6
    6 volt 6 Cylinder. I will let you know if it works!
  13. Bullington
    Bullington
    Update the Petronix doesn't work due to it being postive ground. Needs to be negative ground. Custom order from Petronix
  14. rustingbucket
    rustingbucket
    Petronix definately has one, I have it in mine. I'll try to find the part number. It's a simple install, and works like a charm!
  15. Bullington
    Bullington
    I have talked to them several times. I would love to see what you have.
    Here is what they are having issues finding.
    218 Flathead 6
    6 volt negative ground.
  16. Mad~Max
    Mad~Max
    Plymouths are positive ground. Unless you modified it.
