PND21R Hydramatic question
Discussion in 'The Hokey Ass Message Board' started by Squablow, Jun 12, 2005.
  1. Squablow
    Squablow
    Does anyone run one of these, and if so, do they feel strange to you? Shifts fine once I'm moving, but seems like I have to use quite a bit of throttle before she gets going. Is it slipping, or am I just not used to this set up? It's in a mega-heavy '64 Olds with a 394. Trans fluid looks nice and red-clean, there's no filter in it, just a pickup tube with a screen. Any suggestions?
    Here's a (bad) pic of the car for inspiration.
  2. squirrel
    There's no stator in the fluid coupling, so it doesn't have the torque multiplication of a "normal" automatic ****** at low speeds, like you're used to.
  3. Squablow
    Squablow
    Wow, that's great to know. You really know your ****. Thanks for the tip. I guess the car's fine, it just felt different than other automatics I've driven.
  4. Brandy
    Brandy
    from Texas
    Is this the same sort of Hydramatic as in my 55 Pontiac? I rode in Ragdoll's 55 Pontiac in Paso and that thing shifted SO HARD! I almost got out screaming at the thing! It didn't shift nice and smooth like my Powerglide at all! Is that normal? What should I expect?
    **x
    Brandy
  5. yorgatron
    yorgatron
    you might want to adjust the kickdown linkage.
  6. squirrel
    ummm...don't get carried away!
  7. Andy
    Andy
    I think a 64 Olds would be the twin turbo hydromatic. I believe it had two torque converters back to back. Also known as the slim jim I think. I had one in a 63 Olds and it always shifted and acted funny. I am old and stupid so all this may be wrong.
  8. squirrel
    yeah, it's also known as the dual-coupling, which means it has two fluid couplings.
  9. Rocky
    Rocky
    Classified Editor
    Yeah, they're also know as a Piece of ****, if I remember the correct wording. I hate these things. Everytime I drive one, I hope it makes it another 2 miles before it ****s the bed...they freak me out completely.
    Brandy..the 55 Olds/Pontiac ****** is the slant-pan hydro. It's a 4 speed automatic that will shift hard if incorrectly adjusted. After bring the ****** into correct adjustment, it will shift hard but not as hard. Expect 2nd gear rubber from one under full throttle shifts.
    Really, they're not a bad shifting ****** but those 56-64 Olds/Pontiac slim Jims take approximately 43 mintues to shift from one gear to another and they feel like they're slipping all the time to me...also, the gear ratios are wierd! The engine will wind up in first and fall about 4000 rpm when it finally completes the 2nd gear shift. The shift into 4th gear is imperseptible...feels like 3rd is just slipping......
  10. Jobe
    Jobe
    from Austin, Tx
    I have a jetaway hydramatic in my 1962 caddy. Same thing...mine varies on use and operating temps as to how and when it shifts. sometimes smoothly, sometimes hard, sometimes early, sometimes late or not at all where I have to shift into N then back into D to get final gear. They are unique year to year and brand of car for parts. I dumped some trans-x into mine recently and that helped some. At least it works for me on a daily basis...
    when it goes south I have the option of using a wilcap adaptor and running a turbo400 or 700r4 at least.
    good luck
    bryan
  11. Brandy
    Brandy
    from Texas
    Ha! Leave it up to my Pontiac guru to come ridin to my rescue!Whew! I thought for a second there that I was gonna be stuck in one heck of a cool car, with a brand new motor and some ****y hard shifting POS! I loved my Powerglide. It shifted Soooooooooooooooo smooth......too bad it just didn't shift more then once!:D
