Pnn gasket 350 turbo trans
Discussion in 'The Hokey Ass Message Board' started by pincher, Jul 17, 2012.
  1. pincher
    pincher
    from Saginaw
    Ok Guys , I have a 350 Turbo trans. Want to replace the rusty pan with a new one. Rubber gasket to be put on. should i put the gasket on dry or a thin coat of sealant. I am thinking dry, but a did a search and found that some put a thin coat of sealant on. Just looking for more imput. Thanks.............PINCHER
  2. pincher
    pincher
    from Saginaw
    Pan, My typing Stinks.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Dry
    That i should be capitalized and you need a question mark after sealant also ;).
    If you want to edit your ***le, do an edit then find the "go advanced" and click on it. That will let fix the ***le.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I was surprised when I asked that very question at the transmission shop that we had my Kid's th350 in for repairs about a year ago. They told me they hate rubber gaskets and only use cork, and to put them on dry. They feel the sealants shrink up after a while and leaks can happen. I took their advice, put a quality cork on on, and no leaks so far.
    Like everything else, there are probably a bunch of different opinions on this one though.
    Don
  5. jazzbum
    jazzbum
    i've always used dry rubber gaskets and have never had leaks at the pan afterwards. i used sealant exactly one time, and it leaked. that was with a cork gasket--not sure if it was the sealant or the cork or some combination of the two but i've used rubber since.
  6. blue57ford
    blue57ford
    I agree about the rubber gaskets. We use only cork. Rubber gaskets and chrome pans are in my opinion, no-no's.
  7. squirrel
    No sealer....and make sure the pan is straight, clean the case off, and tighten the bolts to the correct torque.
  8. outlaw256
    outlaw256
    ive never used any sealer on a trans pan. i also use rubber gaskets with no problems.after i unfold them from the box i let them sit awile with something on them to help them stay flat. then i use a little grease on the pan lip and put on the gasket.never had a leak.i do know a guy that used blue glue on his and when it dried he really had problems. seems he put alot of it on there and it broke up inside the pan and stop up something which in turn burned up a ******.
  9. unkledaddy
    unkledaddy
    The best trans pan gaskets I've ever used are FARPAK or Armstrong ACCOPAC.
    They're not rubber and they're not cork, but more like a black fibrous material. I was able to purchase one the last time at 'Whatever It Takes Transmissions' which is nationwide.
  10. detroitboy27
    detroitboy27
    from katy, tx
    No sealent on rubber, but i m***aged a little ****** fluid on it and let it soak for about 10 minutes before install
  11. mustang6147
    mustang6147
    from Kent, Ohio
    I like rubber. My biggest pet peeve with cork is, it will split if even slightly over tightened. Cork in my book is very unforgiving.
  12. Hotrodhog
    Hotrodhog
    I only put in in dry AND clean pan and ****** flange with laquor thinner...seems to work best for me.
    P.S. I hate silicone sealant....
  13. DYNODANNY
    DYNODANNY
    I have used those finned aluminum pans with some toyota (sorry to use that word) f.i.p.g. sealant made for transfercase seal. Works well.
  14. scrappybunch
    scrappybunch
    from nj
    I vote no for rubber gaskets or chrome pans.
    Like another poster recommended the black fiber gasket is best or 2nd best would be cork install dry no sealant. Torque to 100 to 120 inch pound.
