points distributer to electronic
Discussion in 'The Hokey Ass Message Board' started by BrownCow1992, May 26, 2013.
  1. BrownCow1992
    BrownCow1992
    from joliet il
    I am converting my points distributer to a electronic. Any one have any suggestions its on a ford
  2. S2X01
    S2X01
    I was pretty happy with the Accel unit I got for a Buick sometime ago. Easy install and it worked like a champ.
  3. RalphyBoy161
    RalphyBoy161
    Pertronix.com seems to be the place everyone goes
  4. Mr48chev
    Send it to GMC Bubba http://www.lindertech.com/ here on the Hamb along with the appropriate handful of cash and have one that works when you get it back.
  5. jimbanner
    jimbanner
    I've had Petronix in my Flathead for a few years now and have always been happy with it.
  6. gimpyshotrods
    gimpyshotrods
    Depends on the Ford. If you are in the Load-O-Matic era, you are better off with a different distributor.
  7. crazy_tonguezz
    crazy_tonguezz
    from glendale
    i just posted asking the same question for my mercury 390 , ill be following your post incase i find some good information. if i get some info ill let you know too.
  8. crazy_tonguezz
    crazy_tonguezz
    from glendale
    can you give more details to why Gimpsy? like on mine i have a 1963 Mercury Monterey with the ford 390
  9. gimpyshotrods
    gimpyshotrods
    I am not too sure that that you have one. If you do, and for those who do, here's a good read: http://m571.com/yblock/loadomatic.htm
    In short, any distributor, with real mechanical advance, is better than a Load-O-Matic.
  10. crazy_tonguezz
    crazy_tonguezz
    from glendale
    thank you i appreciate your input .
  11. gimpyshotrods
    gimpyshotrods
    Here we go again....
  12. acme30
    acme30
    from Australia
    I dropped a crane fireball unit (similar deal to petronix) into my stock ford distributor and I am very happy with it.
  13. fastrnu
    fastrnu
    from shelton,wa
    pertronix! under $100. Take ya a half hour to do. Follow the instructions. Anyone can do it.
    Or ya'll can sit here and spend days talking about it Pretty sure with well over 100,000 members theres got to be at least another 90,000 opinions. Just pick one
    Keep It Simple Son
  14. crazy_tonguezz
    crazy_tonguezz
    from glendale
  15. eadiepbb
    eadiepbb
    from london
    I was pretty happy with the Accel unit I got for a Buick sometime ago.[​IMG]
  16. I just posted last week on an OT forum (early porsche) asking about electronic ignition conversion. All I got was a bunch of bitching about fixing a problem that isn't a problem. Well, I've been pretty happy with the hei s that I use in sbc s.
    It was advised that if I switch I'd better carry the old distributor with me for on the fly repairs. So, why the bad sentiment anyway?
  17. gimpyshotrods
    gimpyshotrods
    Some guys here hold it up as a merit badge to be hypercritical of things that they don't like, as well as some who believe it a point of merit to waste as much fuel as possible, even when tuning, or better components are within easy reach.
  18. 40FordGuy
    40FordGuy
    Ditto...Pertronix....... Just follow the easy instructions .
    4TTRUK
  19. deadbeat
    deadbeat
    Pertronix in my wifes 63 Thunderbird for 5 years now,just setup & forget.Still use points in my other FE engines though. the reason for electronic in her T/Bird was the dizzy was worn out,needed new bushes,still does,lol
  20. lothiandon1940
    lothiandon1940
    ......I've had good luck with the Crane Fireball conversion as well.
  21. BrownCow1992
    BrownCow1992
    from joliet il
    Am I able to use any of these with a msd blaster 2?
  22. BrownCow1992
    BrownCow1992
    from joliet il
    coil? it has little prong for quick plugs for the electronic I beleave
  23. plaintoast
    plaintoast
    from mora
    I just installed the mallory piece on a sbc and used a new blaster 2 coil with it. Ran straight voltage to it and worked fine. Mallory says to use their coils but the blaster is a great piece.
    I just ran mine to break in on my stand, but noticed some strange behavior as far as timing. Pretty basic sbc with a tunnel ram but it wants about 50 degrees of timing for some reason, just to run. Anyone else seen anything like this with their conversion?
  24. crazy_tonguezz
    crazy_tonguezz
    from glendale
    just got this from a post reply to me
    crazy,
    Have you already dropped cash?
    A lot of the fellas use petronix ignition and I have used it with good success myself. I am partial to mallory unilite though and given a choice I will go for it nearly every time.
    There is an option that no one has mentioned and no doubt that you have not considered. An MSD box with your points will work as well and any electrinic, your points last a lot longer with this setup as thay are only a trigger. And yoy have an added bonus that no one considers at all. It the box takes a dump about 30 miles the other side of Stayl Sandwhich or Pig Snarf all you do it bypass it and cruise home on your stock ignition. No extra parts to carry. <!-- / message --><!-- sig -->
    __________________
  25. 66juiced
    66juiced
    from Austin tx
    I put a pertronix on my 300 i6 and have been really happy ...
  26. BobF
    BobF
    from Poway, CA
    X2 on the Pertronix. Put one in our 66 Fairlane I6 a couple years ago, no problems, put the points/cond in the glove box, still there.
  27. okiewelder
    okiewelder
    from central Ok
    If you can put a ford duraspark dizzy in there why not just use that? I have been running for those for years and they are idiot prof. What engine are you running? That would help for sure
  28. gimpyshotrods
    gimpyshotrods
    Neither the Pertronix, or the Unilite module require that the distributor be modified. Just put the points, a feeler gauge blade, and any extra screws in a baggie, and put them in the glove box. In the unlikely event of an electronic failure, just put them back in.:eek:
  29. BrownCow1992
    BrownCow1992
    from joliet il
    I rebuilt my 1971 429 with a stock distributer with advanced timing
  30. Hefty Lefty
    Hefty Lefty
    When it's raining like hell or 5 degrees or 110 out you will wish you'd left the points distributor in one piece so you could just swap it out. Get a second distributor and keep the original one as is so swapout is somewhat easy.
