Points..dodge hemi..part #???
Discussion in 'The Hokey Ass Message Board' started by Topolino Kid, Sep 5, 2013.
  1. Looking to find part number for points for my 325 dodge hemi....ordered some from Auto Zoned~Out....and they're wrong...Jbackwards J28 pn they got..but they're.Jbackwards:eek:..
    Thanks...
  2. DYNODANNY
    DYNODANNY
    I changed mine out to a pertronix unit. Way better now.
  3. willys1
    willys1
    from South Ga
    X2 MUCH better
  4. Ok.from who and how much??:confused::confused::confused:
  5. 40FordGuy
    40FordGuy
    Definitely go Pertronix... They have ads in most ofour magazines, along with their website.
    4TTRUK
  6. 73RR
    73RR
    If electronic is acceptable then why not use a Mopar system? The older caps and rotors are not cheap when needed and the Mopar replacement parts are available everywhere...you can ***emble a system from boneyard parts if you don't want to buy a performance package (P3690426)
    ...IIRC pertronix parts are not inexpensive or readily available everywhere...
  7. da dodge brother
    da dodge brother
    from wisconsin
    I'm running the 270 Dodge Hemi in My '55. Don't know if the distributor is the same as in the 325 but I installed a stock Mopar electronic unit from a early 80's low deck 318. Drop in. Get the ignition module, hook it up and go.
  8. 73RR
    73RR
    Only the 241-260-270 are a drop-in. The 315-325 uses the same 'newer-taller' intermediate shaft/gear as the DeSoto and the 331-354. Yes, it is also possible to extend the tang on the dist shaft but then you have a one-off part. No big deal to some and huge problem for others...:cool:
  9. For me, right now I'm good with points..easy to change, carry an extra set......i carry a small tool pouch with miscellaneous goodies in it for the road...
    So, anyone got the right part number??
  10. stillrunners
    stillrunners
    from dallas
    Standard brand "Blue Streak"
    59-57 - ALL...AL4652XP POINTS
    56-50 SAME EXCEPT - IAP DIST - AL-5657XP - POINTS
    CONDESERS LOOK THE SAME FOR ALL YEARS - AL-118X
    ROTOR - 59-57 - AL-111X
    56 - 50 - IAP DIST - AL-118X
    CAP 59-56 ALL - AL-130
    56-50 - IAP DIST - AL-98
    there is a 56 dist that is the same as 57 up but it doesn't give the # like the IAP and IGS are the same...
    lwf
  11. stillrunners
    stillrunners
    from dallas
    messed up on the cap - should be 57-59 instead of 56-59....
  12. Well that ****s..auto zone only showed one other set available...Al 1041 MV.....sounds like from your info that's gonna be the wrong set...thanks.....time to check rock auto, ect...
  13. ordered these 59-57 - ALL...AL4652XP POINTS and they would mount on the opisite side of the dizzy................also the Holley dizzy that came in my first hemi, 354, mounts similar to my 325 dizzy..except the 354 has a second hold down screw by the mounting pole..........
  14. stillrunners
    stillrunners
    from dallas
    is there by chance - a distrib tag on yours ? .....it much like a carb tag....which often is missing - does your's have one ? share the number if you do....
  15. i'm at work, but I"ll look tonite..haven't noticed one...but it could be on the back side
