Technical Points ignition/condenser question
Discussion in 'The Hokey Ass Message Board' started by Dave Downs, Aug 7, 2021.
  1. Truck64
    Truck64
    from Ioway
    Ha! Not too many people understand that reference.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And I don't even play guitar.
  3. Dave Downs
    Dave Downs
    from S.E. Penna
    OK, back to points distributors for a quick question.
    Does the capacitor/condenser have to be mounted inside the distributor?
    It seems to me you could hook it up to wire coming from the coil at the connection where it goes into the distributor as long as it is grounded, preferably directly to the distributor body.
  4. squirrel
    no, it can be outside....the old Mallory dual points had it outside, a big can. But it doesn't really matter. Inside, it's better protected, so it doesn't have to be as well made
    Guy Patterson likes this.
  5. Guy Patterson
    Guy Patterson
    Jim you are correct on spark jump and air density
    squirrel likes this.
  6. blue 49
    blue 49
    from Iowa
    On the subject of condensers, would connecting one into the hot wire of my radio work to filter the interference from my AM radio?
  7. squirrel
    It might help. GM used a condenser on the positive terminal on the coil during the 12v point ignition AM radio era (1955-74)
  8. tubman
    tubman
    Condensers for eliminating interference on radios is a little beyond my bailiwick, but I have seen them on generators, oil pressure senders, voltage regulators, instruments, ignition coils, and various other places on different cars. My '51 even has devices inside the grease covers on the front hubs to eliminate it.
    It seems to be a little more complicated than one might think.
    lippy likes this.
  9. G-son
    G-son
    from Sweden
    It's absolutely more complicated than one might think. There are loads of electronic filters out there, sometimes they use capacitors, often they use coils that the current has to go through (remember, coils hate fast changes in the current, so high frequency interference being very fast changes will have trouble going through).
    I can't figure out exactly what you are dealing with, you say you have interference coming OUT OF your radio, what is it interfering with? When dealing with radio frequencies it may easily come out of any wire coming out of the device, using them as antennas, as well as straight through the box if it isn't built well for stopping interference.
  10. blowby
    blowby
    from Nicasio Ca
    Well I started poking around for one, then realized there's an App for that! Just have to figure out how to connect the coil wire to the usb port. :)
    Seriously, there are a bunch on CL around here. Does it have to be an automotive one?
    Truck64 likes this.
  11. squirrel
    I posted a picture of a scope pattern earlier in the thread, it's a Tektronix 535a that I used to have. Fully HAMB approved, built in 1959, contains gobs of vacuum tubes, and ****s half a kilowatt just sitting there.
    Be careful using modern scopes, that are designed for solid state work...the primary side of the ignition system actually has several hundred volt spikes, and can fry things that are not made to deal with it.
    G-son likes this.
  12. lippy
    lippy
    from Ks
    No wonder Amelia Earhart could'nt get her SOS out. lol
  13. Truck64
    Truck64
    from Ioway
    The utility provider has to fire up a peak load electrical generating plant when that thing gets turned on, eh?
    I like vintage electronics, and test gear is no different, so vacuum tubes don't scare me. But they also made solid state ignition scopes w/ CRTs well into the 1970s or so for hobby users. Heathkit and others, everybody knows about the big SUN units but there were many less expensive models out there. That auction site will have a bunch of them.
    The big thing to look for probably is make sure it is complete with all the cables, and the manuals and schematic are a plus. You want one that works, but that's tough to gauge. The one I bought was a Heathkit built in the 1960s and works very well, I replaced the power supply electrolytics on principle.
  14. G-son
    G-son
    from Sweden
    No, it absolutely does not have to, but you do want a storage oscilloscope that has memory that keeps showing the waveform so you can ****yze it after the fact, a simpler oscilloscope w/o storage function will just let it flash by on the screen once and then it's gone - good for identical signals that repeat over and over several times per second or more but close to useless to find that one glitch that shows up once in a while - if you blink when it happens on the screen you missed it.
    Don't get me wrong, my 30 year old ****og scope w/o any storage functions is still great, and for some jobs it's better than other scopes. But the storage functions open up so fantastic possibilities on top of what the basic scope can do.
    You also have to think about the voltage the scope input can handle. Many measure up to 5V/division on a 8 division high screen, so it can show +/-20V on the screen. The inputs can often handle a couple of hundred volts before damaged, but as others say, the voltages in a 12V system can go very far above 12V. I included this same image earlier, it's the voltage over a basic 12V relay when it's turned off. This one gives off a spike of -270V, far above the 100V my (cheap, non automotive) Picoscope USB oscilloscope is supposed to survive.
    You use attenuators between the scope and whatever you measure, most basic oscilloscope probes have 10x attenuation as an option, meaning they'll reduce the measured voltage to 1/10, i.e. 200V to the probe means 20V going through to the scope input. Not quite enough to measure primary voltage at an ignition coil (or the shown relay) as that can go far above 200V, but there are other attenuators more suitable. Just something you need to think about before hooking up a scope, unless you're prepared to fry it.
    As for the oscilloscope software/apps that use the microphone inputs on a computer and such. Perhaps a fun toy, but as the input is meant for low level audio signals it can't handle DC or low frequency, it can't handle frequency above around 20kHz (painfully low), and the max input voltage before damage occurs may be less than a volt. It's more of a toy to test how oscilloscopes work, rather than something to actually use as a scope.
  15. squirrel
    The size of the condenser has something to do with what frequencies it will be able to filter. The smaller it is, the higher the frequency it can deal with. Large ones are good for lower frequency stuff (ie. large electrolytics as filter capacitors in linear power supplies)
  16. Blues4U
    Blues4U
    from So Cal
    You're talking my language. The problem is mostly with electrolytic caps that had about a 15 year design life and are multiple times beyond that now. Coupling caps and tone caps can and do get leaky, but you don't change them unless they're causing a problem. Opening up an old amp to see all brand new orange drop caps is a let down, and devalues the amp. Leaky caps won't really roast anything, but they can cause some unwanted distortions or oscillations. The grid of a tube isn't supposed to have DC on it, so that can cause some unwanted noise; as will DC on a potentiometer, will cause it to be "scratchy". But when it comes to vintage gear, if it aint broke, don't fix it.
  17. Blues4U
    Blues4U
    from So Cal
    The issue here is stray radio frequencies (RF) being picked up and amplified by the radio. I doubt putting a capacitor on the hot wire to the radio will do anything to help, because the rf is not likely coming from there, it's more likely coming from your ignition system, especially if you have solid spark plug wires and/or non-resistor plugs.
    Try putting a loop in the high tension lead from the coil to the distributor. Many years ago I had a problem with noise in the AM radio, the frequency followed with the RPM of the engine. My dad told me to put a loop in the coil wire, which I thought was strange advice, but what the hell, why not try it. It did the trick, no more noise in the radio.
    BigRRR and 427 sleeper like this.
  18. MickD
    MickD
    Wow ! I just opened up this four year old thread. What an interesting read it's been.
    I was trained in electronics and remember a lot of this stuff, but that was in excess of 52 years ago, so there's a fair bit of fog in my memory about this stuff. Interesting how it all starts flooding back though after a bit of reading.
    One interesting thing I've noticed reading this forum is that only four years ago, the dialogue back and forth is SOOOO much more respectful and friendly than reading the **** from the "keyboard warriors" that screech at each other on facebook these days.
    It's been refreshing!
    I knew there was a good reason I joined the HAMB a few years back
  19. Chiefrider
    Chiefrider
    from Lower 48
    Many years ago (around '78) a girlfriend asked if I might be interested in her friend's car as she wanted to get something that ran better and used less gas, like a Honda car. So she brings it over, and it's a cherry 63-1/2 Galaxie 500, pale yellow with a perfect black interior, but the 390-4V was running pretty bad and smoking like a stove. She says could you give me $200 for it? Well OK... So I dive in, last plug on each side is oil fouled, oil drainbacks in the heads were completely clogged, easy enough. Cap comes off, points a little crusty, but it would start right up, just ran bad. Something didn't look right- went over and looked at one of the other cars, and it hit me- there was no condenser in it. Scrounged one from the junk box, and it ran perfectly. I put new points in it, and just for the hell of it tried to start it without the condenser, no go- still haven't figured that one out
    Sharpone and jimmy six like this.
