Technical Points set up 1949 Flathead 6 V positive grnd
Discussion in 'The Hokey Ass Message Board' started by Overhaulin, Jul 21, 2015.
  1. Overhaulin
    Overhaulin
    from Ohio
    I've got a distributor with no points or wiring inside. Can anyone tell me how to wire up a new set points, condenser, and ground?
    Thanks!!
  2. stillrunners
    stillrunners
    from dallas
    kinda goes like this.....maybe others have a better view..... distributor.jpg
  3. Bruce Lancaster
    Bruce Lancaster
    On yours, I believe that your primary/low tension wire comes in through floor of the main body through a grommet. It then snakes up to bolt onto the points. The wire and grommet should be checked carefully to be sure all is solid and not in danger of grounding out from a bad grommet. You also have a little woven bare wire connecting the points plate to the distributor body below for a ground. This should also be carefully checked, as it can break down from decades of point plate movement. Drawing here: http://www.vanpeltsales.com/FH_web/FH_images/FH_engine-pics/Flathead_Distributor_1949to50.jpg
  4. Texas Webb
    Texas Webb
    Nice picture from Stillrunners.I noticed there is no wire from the other terminal at starter switch?
  5. Doesn't happen on 6V. The points get full voltage all the time. On 12V you have a hot start mode because the voltage is dropped from 12V to the points in run mode.
  6. ClayMart
    ClayMart
  7. Overhaulin
    Overhaulin
    from Ohio
    Thanks guys!!!
