polishing carbs
Discussion in 'The Hokey Ass Message Board' started by jerdan, Feb 20, 2013.
  1. jerdan
    jerdan
    I have a Holly carburetor I would like to polish. How do you suggest I go about this? What do you suggest I use?
  2. black 62
    black 62
    from arkansas
    is it chrome?---if not, i think you will be wasting your time---friend of mine tumbled a carb body once---it looked kinda shiney...
  3. PackardV8
    PackardV8
    Good hobby for someone in for life without parole. It's about the most time for the least result. The Holley is full of inaccessible radii, bends, folds, corners. It would take a box full of Dremel accessories and a magnifying lamp. Also, the zinc body shows every little grinder mistake, so it requires going slow and carefully taking off the casting flaws.
    Then, when done, it's covered with an air cleaner.
    jack vines
  4. Normbc9
    Normbc9
    Ask **** York at ****s Hot Rod place in Franklin, IN. He has a service that will does this tedious chore for you.
    Normbc9
  5. gasolinescream
    gasolinescream
    As Jack says, kind of job you'll do once and never again. However if you want a nice looking carb on the cheap this may of interest. I've used this many times, works a treat if you get the carb reasonably clean and remove any crusty stuff before hitting it with the soda. Kept the link sent from a friend of mine who's into his VW's.
    http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
    Just an idea......
  6. black 62
    black 62
    from arkansas
    is that evonne dicarlo?
  7. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    get your self a can of br***o & a couple of tooth brushes some terrycloth & a whole lot of patience.
