Technical Polishing plastic reverse lenses
Discussion in 'Traditional Customs' started by Big Swede, Nov 22, 2016.
  1. Big Swede
    Big Swede
    Howdy,
    I've gotten my hands on a pair of NOS reverse lenses for my '55 Plymouth. They're damn near perfect aside from a few fine scratches/rub marks from the inside of the no in which they came.
    Has anyone used anything special to polish plastic like this? Looking for any recommendations.
    Thanks!
    Frank
  2. mohead1
    mohead1
    Ive had good results in the past w progressive sanding, like 600 to 1000 to 1500, then compound buffing
    Big Swede likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    X2 the finer the better , Polish With tooth paste
  4. Murphy32
    Murphy32
    from Minnesota
    This is the stuff:
    ...polishes plastic like no tomorrow !!
  5. Terrible80
    Terrible80
    I found some stuff called 'lens gloss' they have several other products, works great.
  6. Big Swede
    Big Swede
    Thanks errbody. The scratches and rub marks are really too fine to get after with sand paper. I'll give the plastx a go and see how it goes. I get one shot. Apparently these lenses are rarer than hens teeth......
  7. I'll second this. If they're too deep for this, they do make a dedicated polishing compound for use with a loose cotton buffing wheel, but make sure you don't go over 1800 rpm on the wheel speed.
  8. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Then practice on something a little less rare ;)
    Big Swede and CowboyTed like this.
  9. 19Eddy30
    19Eddy30
    from VA
    Toothpaste .50 cent !!!
    Big Swede and prewarcars4me like this.
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    Use abrasives to get scratches out and continue to refine the scratch as fine as you can go...grab a 3" polisher and a 3" compound pad along with some rubbing compound and make those baby's look brand new. I have done several friends and neighbors headlights over the years
  11. Jon SSS
    Jon SSS
    No to toothpaste! Most have chloride in it which will clean but dull the surface. PlastiX is the ****. I use it all the time. Great stuff. Guitars, plastic in large picture frames, plexi windows on race cars and old metalflake helmets just to name a few.
  12. David Gersic
    David Gersic
    from DeKalb, IL
    Find a local motorcycle shop and get Novus plastic polish. #3 followed by #2 should do it. Also works good on cycle windshields and helmet face masks.
  13. robracer1
    robracer1
    Believe it or not try White Diamond the best metal cleaner and polish I've used and works great on plastic
  14. 19Eddy30
    19Eddy30
    from VA
    Just Regular toothpast ,, Not no fancy one's, Plain jain toothpast like closeup Red !
    The Trick Is, the smoother it is ,the easier it will polish better results ,
  15. LWEL9226
    LWEL9226
    from So. Oregon
    Get a headlight polishing kit for the newer cars, works good......
    Lynn W
    Big Swede and mgtstumpy like this.
  16. jailbar joe
    jailbar joe
    I had a pair of sunnies that were too scratched to use so I gave them a go on my sisal buff a very fine one and used blue rouge they came up a treat.....this is the set up I used for my stainless firewall
  17. Big Swede
    Big Swede
    I'll practice on the one I have left on the car. It's seen much better days but is unrestorable as is.....
  18. 55Thunderboy
    55Thunderboy
    from NYC
    go get yourself some 3M Trizak off Amazon or locally, they sell these in packs which have a foam backer in 2000, 3000 and 5000 grits. I just discovered this stuff this year and its amazing on polishing lenses. I wet sand up to 5000 and then take my drill with a 3 inch wool pad and some NOVUS fine scratch plastic polish and the results are perfect. I practiced on my wifes car and got the hang of it quickly. Trizact is expensive but its so worth it, il never use anything else now, i even use this to polish stainless and aluminum by hand with some Mothers.
  19. BamaMav
    BamaMav
    from Berry, AL
    White liquid jewelers rouge. Can find it in the truck stops as a aluminum polish. I have used it to polish scratches out of eyegl***es and sungl***es.
  20. FunnyCar65
    FunnyCar65
    from Colorado
    Sand them with 800 grit then clear coat with a good quality clear. They will look better then new red lenses really look good after.
  21. Engine man
    Engine man
    from Wisconsin
    Back in the 70s at a used car dealer, I polished paint, windows, plastic emblems and lenses with the same Ditzler compound. I think it was DRX25.
  22. CowboyTed
    CowboyTed
    So the end result of all these replies is that polishing plastic is just a process of abrasion. You have the option of using almost any sort of abrasive. Rubbing and polishing compounds for cars' paint works well on most plastics, jeweler's white diamond compound, Tripoli, Zam or rouge all work well if you have a rotating polishing buff. More liquid types of polishing compound are easiest if you are polishing by hand.
    The trick is to start with a compound or sandpaper that is co****, but just as co**** as needed to remove the scratches you want to polish out. When you have attained a uniform surface with co**** compound, switch to a finer compound to remove swirl marks left by the co**** stuff. Then use progressively finer compounds until you are happy with the shine.
    Polishing plastic is the same process as polishing paint, silver, gold, aluminum, stainless or wood. It's just abrasion, using finer abrasives in each step. The only caveat is that plastic can be affected negatively by the acids contained in some compounds, particularly compounds meant for polishing metals. I would try whatever polishes you already have around the house or garage. Test each on an incon****uous area first to make sure it doesn't contain an acid that reacts poorly with your particular plastic formulation. If you have to go out and buy a polish, get something that is intended for plastic, like headlight or motorcycle winsdscreen polish.
