Poll: Motor choice!
Discussion in 'The Hokey Ass Message Board' started by flatout51, Feb 13, 2011.
  1. Big Block Ford FE
    76 vote(s)
    46.6%
  2. 289 HiPo
    87 vote(s)
    53.4%
  1. Total Performance
    Total Performance
    from Nor Cal
    I'm a huge FE lover. That being said, my opinion is that the FE, while neat and good eye candy, would be less of a road car than if it had the 289. In the end both could be made to run nicely for your perspective project outline. So the choice is really up to you.
    You've gotta let us know your choice though.
    Total Perf-
  2. flatout51
    flatout51
    TIE?!?! Really?!
  3. themoose
    themoose
    No subs***ute for cubic inches........390
  4. jcmarz
    jcmarz
    from Chino, Ca
    I only vote for Chevy motors.
  5. flatout51
    flatout51
    Then stay away from my threads unless you want to be dissapointed.
    Oh and the drag strip......
  6. chuckles0
    chuckles0
    I like / have both.
    >>Power to wieght Ratio.. ..289 will pull that like '29 just fine..My RPU weighs in at 1800# w/302. Hooks up good..decent mileage. Corners nice. rides nice.
    The 390 will be heavy for the front end . *Push in the corners, You'll have to feather it for traction, consume fuel, Beefed up suspension for the .xtra frt. end wt. .Xtra rear suspension to get it to hook. Heavy car. ( you'll have to play 'ketchup' to the small block at the other end..
    >>Power to wt. ratio.. JMO
    I love the 390/330, in my Gal..
  7. slickhale
    slickhale
    from Phoenix
    fe, there shouldnt be a question
  8. mammyjammer
    mammyjammer
    from Area 51
    There seem to be a lot of interest in putting Cads, Nailheads, Olds and Hemis in Model As, but a FE is too heavy?. The "Low Revving Pig" will annihilate the tires with torque and the 289 would be a high revving screamer. Both great engines and you can't go wrong with a Ford in a Ford. On appearance alone I lean FE, but not by much...
  9. shmoozo
    shmoozo
    from Media, PA
    I'd go with the 289, myself, but I sure wouldn't give a guy grief for choosing the FE.
    As for which one you should choose, I suppose before I gave my advice on that I'd want to know what you plan to do with the car after it's built. Is it going to be used for motoring over to the local cruise night where it'll be parked a****st a bunch of other rods, but otherwise not driven so much? If so, I'd go with the FE.
    Or is it going to be driven, and I mean driven a lot, as in a daily driver or used for long weekend road trips? If that's the case then I'd go with the 289 for sure.
    Basically I see the 289 as the more practical engine, and the FE as the flashier, "cooler" engine if you really want to draw a crowd when it's parked.
    As for performance, they'll both make the car plenty fast, though the FE will likely be a bit faster. On the other hand all that extra weight up in the front of the car will have a negative affect on handling and braking, the extra torque will force you to beef up the frame more to keep from twisting it apart on hard launches, and it's probably a given that the FE will consume significantly more fuel. Given the limited gas tank volume available in a model A that could get to be mighty annoying on long trips because you'd have to stop for gas more often.
    Oh, and no doubt about it the FE will be more of a challenge to fit into that car than the 289 because it's just plain bigger.
    Are you sticking with the original cowl fuel tank?
  10. langy
    langy
    They do take up a lot of room in a 29 as you can see here in my old 29 coupe
  11. SIX_94Y
    SIX_94Y
    from Australia
    289 if you want to drive it
    390 if you want to break it.....
    I love to be different but I'd never feel comfortable with a 390 in early rails. Mind you a freind of mine is peicing together a Blown MEL 430 model a coupe project, and he wants it to wheelstand!!
  12. movin/on
    movin/on
    This is planned for either a Model A Roadster or a 60 Vette one or the other is going to have my FE Latham setup.
    BTW I voted FE---
  13. Barry_R
    Barry_R
  14. falcongeorge
    falcongeorge
    from BC
    The Edelbrock F28 is still available new if you want 2x4s, tons of VERY correct nice mid-sixties 289 cobra dress-up parts available from Tony Branda and other cobra/shelby resto guys. Tony Branda also has nice re-pops of the Stellings & Hellings air cleaners that were on the dealer 2x4 set-up. To do a period-correct FE is big coin(I own one) And 289s went through a period in the late sixties where they were quite popular in rods. 289 and a t-10 or toploader would hit the spot.
  15. falcongeorge
    falcongeorge
    from BC
    If its a T-5, and you build an FE worthy of the name, you can kiss that T-5 goodbye, cause it wont be around long.
  16. falcongeorge
    falcongeorge
    from BC
    Some more nice mid-late 289 intakes that are available as re-pops. Triple holley 2bbls, the 1x4 Cobra high-rise, and the circa '67 dual holley intake. There actually a ton of really cool, period parts available for a mid-late sixties 289. Tony Branda has really nice open letter cobra valve covers too. These are all re-pops of intakes that were available over the counter from Ford dealers in the mid-late sixties.
