Poll--tire size
Discussion in 'The Hokey Ass Message Board' started by GARY T., Feb 6, 2013.
  1. 750x16 and 550x16
    16 vote(s)
    72.7%
  2. 750x16 and 600x16
    6 vote(s)
    27.3%
  1. GARY T.
    GARY T.
    from S.W. Pa
    What looks better on a highboy roadster
    750x16 and 550x16,or750x16 and 600x16?
  2. HOTRODPRIMER
    HOTRODPRIMER
    You need to add one more category to your pole.
    Not enough difference to worry about. HRP
  3. 28TUDOR
    28TUDOR
    750x16 and 550x16
  4. ss34coupe
    ss34coupe
    I agree.
  5. GARY T.
    GARY T.
    from S.W. Pa
    In an Excelsior 550 is 26.5" dia------600 is 28" dia
    That 1 1/2"---pretty much difference!
    The 750 is 31.60"
  6. I used to run 9.00x15 and 6.00-7.00 on about everything. But I started building in the '60s.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Omitting that the tires in question are Excelsior's may or may not have any bearing on the question,depending on which size you go with it only effects the height by 3/4" of a inch,,I still submit it makes very little difference.
    I don't think any of us could detect one from another if they are not side by side,,,
    I guess it boils down to what you want,,personally I like a rubber rake some guys don't care for it,,it's a personal preference. HRP
  8. Enough said, I learnt this a while ago; do what you think looks right not what a poll might say.
  9. Depending on th tire and wheel combo a 7.00 may look a little meaty. I would probably run the 6.00 on a roadster.
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    It also makes a difference if it is a T, A, or B roadster...I like smaller front tires on smaller cars...balance is key...fung shway :D
    kidcampbell71 likes this.
  11. scrap metal 48
    scrap metal 48
    I would match the side walls if you can.. Meaning both pie crust and same tire brand..
