Hot Rods Pontiac 389 transmission options
Discussion in 'The Hokey Ass Message Board' started by ab_51Ford, Aug 25, 2018.
  1. ab_51Ford
    ab_51Ford
    So I just picked up this 389 out of a '65 Grand Prix for everyone's favorite price. I was curious what my best bet would be for a transmission. It's going in a '27 T sedan. I'm not sure if I want an automatic or to shift gears myself. Any suggestions??
    Thanks -Andrew
  2. DDDenny
    If three pedals are in your plan and trying to stay "period" Pontiac, the Muncie or Borg Warner T-10 four speed would be my choice.
    mkubacak likes this.
  3. flamedabone
    flamedabone
    A '65 Pontiac will have what is considered to be the regular, normal BOP pattern. Any garden variety transmission that came behind a Buick, Olds, Pontiac or Cadillac will bolt to it. That includes auto and manual.
    No matter what ****** you go with, you will love that little Pontiac.
    -Abone.
  4. Gman0046
    Gman0046
    A 65 389 will bolt up to a 200-4R. Thats what I'd go with.
    Gary
    Hnstray likes this.
  5. Bird man
    Bird man
    from Milwaukee
    Your member profile does not indicate your ***ual "iden***y".
    I always say play it safe & go manual ;)
  6. You have to be certain that your block has the provision for the starter to bolt to the engine block
    Elcohaulic and '51 Norm like this.
  7. flamedabone
    flamedabone
    Yes, double check that. A 1965 block SHOULD have starter bolts in the block, but doesn't necessarily mean does.
    -Abone.
    Elcohaulic likes this.
  8. Poncho60
    Poncho60
    from N Illinois
    My understanding is that essentially all of the 64 blocks are drilled for the block mounted starter, so if yours is a 65 for sure, should be no issue.
  9. The '64 I parted out had the ear and holes. 65 up are standard BOP and I'd be shocked to find one that exists without a block mounted starter.
  10. Gman0046
    Gman0046
    As I previously posted a 65 and up 389 is a bolt on.
    Gary
  11. mkubacak
    mkubacak
    Don't be a ******, use a manual transmission.
  12. Its my understanding that the 55 thru 60 all use the same bellhousing. and the 61 thru 64 use a different type . and those are all bell housing mounted starters. and the 65 and later use the BOP and is a pontiac eng 012.JPG pontiac eng 013.JPG block mounted starter. pictured is a 56 flywheel and bellhousingl
  13. Gman0046
    Gman0046
    Yep, 65 and use BOP.
  14. Poncho60
    Poncho60
    from N Illinois
    55-60 will accept the same bell housings but the 55-57 bell housing is not the same as the 58-60 and is not really desirable as it will not accept modern transmissions like the Muncie, t-10, modern 5/6 speeds, etc.
  15. It has to be drilled. The starter didn't bolt to the THM 400. We know that much.;)
  16. Poncho60
    Poncho60
    from N Illinois
    Since the super hydro (jetaway) for the big cars was done in the 64 model year, there should be no 65 blocks that aren't drilled & tapped for the starter.
  17. Yes however the 56 gears & tailhousing can be installed in a 38 buick case and use the top floor shift.https://www.jalopyjournal.com/forum...ars-tail-housing.1095970/page-2#post-12518374
  18. Gman0046
    Gman0046
    Thats why my 60 Bubbletop has a 1965 rebuilt and .030 over 389 as its a bolt up to a 200-4R out of a Grand National. $1600.00 later for a rebuild and its good to go. 75 MPH @ 1800 rpm's sure helps the gas mileage.
    Gary
    Hnstray likes this.
  19. ClassicDriver
    ClassicDriver
    Just to be clear in my mind... Are you saying the 55-57 bell is the one that is "not really desirable as it will not accept modern transmissions like....."?
    If so, then is it because the "trans side/back side" has a different bolt pattern or is it weaker or both?
  20. The trans back side only accepts the Pontiac trans. Its not weaker than the other. However the 55 thru 57 GMC truck Pontiac bell does accept the 318 Muncie and later GM transmissions.
  21. ClassicDriver
    ClassicDriver
    Now I really confused. Sorry.
    I guess what I looking to know is this: Which year range of bell housing accepts the "...Muncie, T-10, modern 5/6 speeds, etc."?
    AND
    When you say "55-57 GMC truck Pontiac bell". Is the truck bell different then the p***enger car bell for manual trans?
    Thanks...I just want to make this crystal clear in my thick head. :)
    PS: Sorry, don't mean to hijack the thread....
  22. 1955 thru 59 GMC trucks Used Pontiac V 8 engines. and the ones that where standard shift used the 318 Muncie 3 speed or the SM 420 granny four speed. Those truck bells will accept Muncie ,Saginaw , t10 and other later GM transmissions. The truck bell has two mounting pads one on each side.
  23. Poncho60
    Poncho60
    from N Illinois
    Since you have a 65 motor, why all this discussion about the earlier bellhousings? Just get a 65 or later bellhousing from a v8 tempest, lemans, or gto and be done with it. The 55 thru 64 bellhousings either won't work with your 65 at all or at least have issues of some kind. The 65 and later V8 bellhousings eliminate all that ****.
    Gman0046 likes this.
  24. Why all this discussion? Well others that are not the OP ask questions in a attempt to be more knowledgeable. Its certainly not taking any nickle's out of anyone's pockets to discuss all the variables.
    Budget36 and Atwater Mike like this.
  25. ClassicDriver
    ClassicDriver
    Thanks Old Wolf... twice over! ;)
    Atwater Mike and Old wolf like this.
  26. Poncho60
    Poncho60
    from N Illinois
    Ok, fair enough. Just as a final comment, the only bellhousing that will bolt up directly to the 55-60 blocks and accept the later modern transmissions is the 58-60 bellhousing (car) and the mumber cast on that bellhousing is 528820. Dont know about the GMC GMC bellhousing interchange. I do know the stock fork for those is different than for cars. Rocky is up on the GMC stuff as I believe he used that bellhousing on his coupe build. The 56-57 Pontiac std trans is ok for putzing around but will not take the abuse of a performance Pontiac V8.
  27. I reciently sold a 55GMC pickup. It has a factory 287 Pontiac engine and a 318 Muncie three speed trans.
  28. big john d
    big john d
    from ma
    some of the early gto 's used ford top loaders 3speed?
    Old wolf likes this.
  29. Atwater Mike
    Atwater Mike
    GTOs with 3 speeds? Never seen one.
  30. Rusty Heaps
    Rusty Heaps
    you guys were puttting all this info on mid '50s ******s and bellhousings on here for me! I needed that info and here it is at the right time
    sko_ford and Old wolf like this.
