Pontiac 400 Pistons
Discussion in 'The Hokey Ass Message Board' started by redd, Oct 18, 2021.
  1. redd
    redd
    from akron
    I have 2 sets of pistons, for my Pontiac 400 engine. One set has 4 valve reliefs ,and the other set has 8 valve reliefs. What's the difference ?
  2. A lot, I would guess. One is an aftermarket set for a hot rod or racing engine..The other is a rebuilder or replacement item.
    Probably other differences too.
    Of course Lloyd is correct, given the limited amount of info ;-)
  3. Deuces
    Deuces
    How's about pictures of the piston tops????.. one of each piston will do....
    Elcohaulic and lothiandon1940 like this.
  4. SEAAIRE354
    SEAAIRE354
    Loyd your math skills are amazing. Your really wasting your talent on fire fighting and pushing sand paper.
    And I don’t believe I’ve ever come across Pontiac 8 valve relief pistons. Pics or part number would help.
  5. greybeard360
    greybeard360
  6. Thank you
  7. Deuces
    Deuces
    Those are garbage.....:(
  8. Budget36
    Budget36
  9. Deuces
    Deuces
    Interchange with 2 and 4 bbl heads.....:rolleyes::(
    Budget36 likes this.
  10. Budget36
    Budget36
    Or….maybe running 2x4 intake;)
    bchctybob and Deuces like this.
  11. 1pickup
    1pickup
    Nice try, but you forgot he said "set" of pistons. So, 8 in a set means 4x8 = 32(for 4 relief pistons) & 8x8=64(for 8 relief pistons); Then subtract: 64-32=32
    Your answer is 32. @Lloyd's paint & gl*** gets an "E" for effort.
  12. John Milner
    John Milner
    from Oklahoma
    The 8 valve relief pistons were made for both early (389) and later model (400) valve angles. 2 barrel 67 400's had the earlier 20 degree valve angle like a 389. Every 4 barrel 67 400 and later model 400 (both 2 and 4 barrel) will use the later model 14 degree valve angle. Those 8 valve relief pistons are cast and sit way down in the hole and lower your compression. I have seen some that the edge is beveled on to lower your compression even more. They usually sit around .050 down in the hole. I would not use them.
  13. Deuces
    Deuces
    Yep! The Ford high output 5.0L engines from '87-'91 were factory equipped with TRW forged pistons....
    Elcohaulic likes this.
  14. stuart in mn
    stuart in mn
    This is the correct answer.
    Deuces and Mark Yac like this.
  15. sunbeam
    sunbeam
    So if they are standard you bore the 389 .060
  16. Nothing wrong with a set of 455 L2359 TRW forged for a street or Bracket engine. They are 4 eyebrow, multi-directional , of course. Don't know the 400 number, off hand.
