Pontiac guys, I need help
Discussion in 'The Hokey Ass Message Board' started by davedeltadog, Mar 17, 2009.
  1. davedeltadog
    davedeltadog
    I have a 350 Pontiac in my 56 F100. It needs a new drivers side engine mount, but I don't know what model the engine is from. Went to the NAPA store and looked though some catalogs but didn’t find a match. They had a 1970 Firebird mount, but irt was several inches longer.
    Check out the pics and see if you can help. The total length is 6“ and all bolt holes are 7/16” in dia. The distance between the mounting holes centers is 5-1/8”(5-1/2" in photo is wrong). The distance between the saddles is 3-9/16”.
    Thanks, Dave
  2. wild willey
    wild willey
    Hey why don't you check for the similarities with what you have and compare them to a mid seventies (74 to 76) motor mounts. The one pictured looks very similar to the ones on my 75 formula 400.
  3. twotoejoe
    twotoejoe
    Check with performanceyears.com I believe they sell those new.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That looks like a '64-'69 style mount to me.
  5. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Hey Dave-Shoot us a pic of Your motor, please.
  6. e z i
    e z i
    I have a 1971 Lemans motor in my 1956 GMC, and the mounts look like
    the one's in your picture.
  7. shpotty
    shpotty
    from New Jersey
    The mount you are looking for is the "early" style unit, pre-1970. The '70-'74 units are longer and the ones after those are different altogether So look for a motor mount for a '68 GTO and you should be good to go.
  8. Kerry67
    Kerry67
    Get ahold of AppleKrate.....The Pontiac Guru.
  9. davedeltadog
    davedeltadog
    Here is a pic of the engine, I did a serial number reference on the engine it's a 1974 block, I looked at some mounts in Ebay and it appears they are 68 to 74 Lemons. Thanks for all the help
  10. Richard Head
    Richard Head
    The mounts on my 67 GTO look like that.
    Dave
  11. screamingchief
    screamingchief
    from Austin,Tx.
    That's an A-body mount.
    The longer mount you mentioned may be the '70 up F body mount,that mount uses a completely different set of holes on the side of the block,the '69 and earlier pontiac blocks dont even have the bosses to mount the second gen F body mounts.
    So as some of these guys said,ask for a mount for a '68 to '72 tempest,lemans,GTO,as that should be what your looking for,just make sure it's for the 350 or 400 pontiac motors,as the '70 to '72 455 A-body mounts are different too,those are longer like the second gen F-body mounts.
    And dont bother with the first gen firebird mounts either,those are totally different,those are the same as the "big car" mounts.
    Hope this helped.
