pontiac intake mod, 65 and up to fit 61-64
Discussion in 'The Hokey Ass Message Board' started by Mr Poncho, Jun 30, 2013.
  1. Mr Poncho
    Mr Poncho
    from PA
    is there a mod to fit a Pontiac 65-up intake and after market ones to fit and work on 61-64 heads, not having any luck finding the right intake, really just curious the real differences between them and why they aren't compatible
    I do eventually want to make my own custom intake but that's much down the road
    also my first thread on here :D
  2. Deuces
    Deuces
    Should have used your 1st post as an intro..:rolleyes:
    I'm curious also... So, here's a bump for ya!...
  3. flamedabone
    flamedabone
    Try these guys, lots of great Pontiac tech over there. Hit the search ****on and you might find what you are looking for.
    www.performanceyears.com
    Good luck, -Abone.
  4. Zerk
    Zerk
    Use a set of '65-up heads and it should work. It would be the easiest solution.
  5. Mr Poncho
    Mr Poncho
    from PA
    thanks guys ill research further into this, and I I recently found a 64 grand prix that's been sitting for decades, its a rust ball but it might have some goodies left on it,looked like it still had the engine( might go for the whole engine if its a SD 4boltmain ), the guy might not let me near it haha but I will find out soon, if that's a no go ill try to get some heads
    I do plan on getting newer heads especially since what iv found out mine are 8.6 or 7.6 to 1 compression but when I do I will take measurements and post the differences between them
  6. You may as well get the whole car and part it out. While the trans is probably ****, the '64 blocks have the ear for a block mount starter like '65 up and the bolt pattern is close, if not the same. (some have just an ear, some have holes, some are even tapped).
    I parted one out a few years ago and did pretty good on it, but I bought it right (s**** price).
  7. 296 V8
    296 V8
    from Nor~Cal
    The pre 65 intake covers some water ports at the rear of the heads and the bolt pattern differs at the water crossover at the front.
    I cant remember for sure but I think the rest of bolt pattern is the same.
    Pre 65 intakes are very common at swap meets …. most people want 65 up
