Pontiac straight 8
Discussion in 'The Hokey Ass Message Board' started by Cucumber, Dec 17, 2009.
  1. Cucumber
    Cucumber
    from Sweden
    Hello! Im just a guy from sweden who has a poncho 52 with the nice straight 8 . Im just thinking that it is a very cool engine but im looking to "tune it up" a little . Does it exist any sort of dual carb manifold or headers to it ? Iv'e tried to search the internet but I don't have any luck finding it. Iv'e seen pics of the eight with four 2 barrel webers , and man it looked sweet.
    I hope I can get some answers here :)
    Sorry for the bad english! / Matthew
  2. PegLegStrick
    PegLegStrick
    Not much in the way of performance parts for the Poncho straight eight. Fenton made an aluminum finned head but they are rare. So is the manifolds.
    Try the search button there is a post or two out there about souping up the pontiac I-eights.
  3. hotrod-Linkin
    hotrod-Linkin
    about all you can do is split the exhaust and fab up a dual carb setup. aftermarket speed euipment is hard to find.
  4. Cucumber
    Cucumber
    from Sweden
    ok thanks for your time anyway :) I will have a look in the pontiac 8 posts. Have a nice day!
  5. bobscogin
    bobscogin
    What bad English? Dude, you have nothing to apologize for. However, sorry I can't help with your question. I don't speak straight 8 Pontiac. :D
    Bob
  6. plym_46
    plym_46
    from central NY
    biggest bang for the buck for any straight flathead is milling the head. Most can have up to .080 taken off and still run regular gas. You are looking at 6 1/2 to 1 compression stock. Talking of the whole bunnch would get you about 8 to 81/2 to 1.
    You can also take some of the block if its getting other machine work done. Freeing up the exhaust with bigger diameter pipe and less restrictive muffler will also take advantage of increase in compression. Make sure you are also getting as much air in as you can. Remember you are dealing with a long stroke engine whose forte is torque at low to moderate RPM, not high hp at peak rpm. Factory HP rating was done at the 3200 to 3600 rpm and read line isn't much higher.
    Port matching the intake and exhaust to the gasket openings can improve flow a bit.
    Add a performance style 2bbl carb and you will probably get as much change as you would with any vintage speed equipment you might find. If you going to 12v, you can probably upgrade to a late model type electronic ignition system for more reliable spark.
  7. 73RR
    73RR
    You do better than 20 million current residents......
  8. Kencary
    Kencary
    from Cary, NC
    The head in my '51 Pontiac 8 is milled and it seems to run fine on pump gas. There were actually 2 heads for these eights a regular and a "high head" the high head had slightly more compresssion but milling the regluar one will do the same.
    It is very hard to tell the high head from the regular one.
    Ken
  9. Rusty52
    Rusty52
    I have a '52 Poncho with the Straight 8 as well. I've also got a spare straight 8 on a stand. The motor in the car has a "high compression" head. As far as I know, the high compression head has it stamped right on the top of the head so it should be easy to identify, but I could be wrong on that. I've seen an aluminum dual carb intake for sale at a local show, it was made by Edmunds and they were looking for $600 or something like that. The guy who had it sells on ebay under the name aluminum man?? if I recall correctly. Either way you could do a search on ebay for that piece.
    You also should check out Dave here on the H.A.M.B. he is a great resource for early Pontiac guys. He has a website 1952pontiac.com that will have a lot of answers for you.
    Good luck!
    Rusty
  10. Brandy
    Brandy
    from Texas
    I think I started a thread on I8's.........lemme look.
  11. Rusty52
    Rusty52
    Brandy,
    Is this yours? That's Saweeeet!
  12. Brandy
    Brandy
    from Texas
    Noooooooooo I hijacked that picture after I asked about running a straight 8 in my Poncho roadster!
  13. Cucumber
    Cucumber
    from Sweden
    yeah I have the high ucompression head with 8:1 comp ( I think? ) Im just 21 years old and Right now im putting in a chevy 283 to have time to redo the straight 8 , it's been overhauled not to long ago but I want it to look like a young guy like me have "hotrodded" it in the 50's . Im member on daves site rusty but my account stopped working ,why I don't know :p Thank's for all your answers It's really helpful , not too many working straight 8s here in the north and parts are nearly impossible to find here . Thank god for america ;)/Matthew
