Technical Pontiac water pump issue.
Discussion in 'The Hokey Ass Message Board' started by wvenfield, Dec 8, 2020.
  1. wvenfield
    wvenfield
    Stuck. 1964 389. The water pump that was on it worked on the car the engine came out of. I understand about plate clearance. Anyway I couldn't get things to work. Put on a 14 bolt pump that came off what was a working 400. Still won't work.
    Pulled the thermostat. Put the upper hose in a bucket. I'm getting absolutely no flow. Radiator full. Engine is verified as full. Start the car and nothing. Not even a dribble.
  2. Are there different pumps available?
    Pump turning in correct direction ?
    Any restrictions at all in engine or rad ( run a garden hose through rad and engine to verify )
    New build?
    Old build ?
    What’s the story morning glory ?
  3. wvenfield
    wvenfield
    New radiator. Engine was done years ago, ran a little and then I bought it. Clean as can be in it. Sounds great running.
    Any way around it, as sitting there it should pump. Pumps absolutely nothing.
  4. J. A. Miller
    J. A. Miller
    from Central NY
  5. Unique Rustorations
    Unique Rustorations
    With the belt off spin the pump in both directions. Does it pump at all in either direction? Is this a stock ‘64 block and heads or post ‘64 heads? What front cover is installed? Randy
    loudbang and VANDENPLAS like this.
  6. wvenfield
    wvenfield
    I'll have to run back down but it's not pumping at all with the belt and car running.
    Stock 64 block with stock heads. It was running fine in the car I pulled it from.
    The front cover is from a 400. 14 bolt water pump. It wouldn't pump with the stock cover and pump so we tried this.
  7. fordflambe
    fordflambe
    Did you install the water pump sleeves inside the front cover when you converted to later pump?
  8. wvenfield
    wvenfield
    Yep.
    fordflambe and loudbang like this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Were the engine cooling p***ages open during storage ? Mice & chipmonks love small storage spaces , mud daubers need a place to make a home ..
  10. wvenfield
    wvenfield
    All checked. All good. It wasn't open......
    Pulled the thermostat. Took the heater plug out. Fills right up. Just doesn't pump.
  11. TCTND
    TCTND
    If I understand, you've tried 2 different pumps and neither works. That would suggest that the pump is not the problem. Something is blocked or airlocked, or the pump isn't primed.
  12. wvenfield
    wvenfield
    We've changed 100's of water pumps. Fill the radiator and the engine fills. You can't watch the water reach the thermostat opening. You can pull the heater plug and watch it fill that far.
    It doesn't circulate at all. Pour coolant into the upper radiator hose and the radiator fills. It goes through the engine.
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you've changed " 100's of pumps" , you should have this under control , I can't imagine your needing anyone's suggestions ...sorry for interrupting ..
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    Pull the pump and check it off the block.
    Something in the p***age acting like a one way valve?
  15. wvenfield
    wvenfield
    The pump is clear. Everything worked fine on the 400. On the 389 cover I even tried a brand new water pump. Checked clearances on all of them.
    The only differences is the radiator now. I've never used a dual flow radiator before but as I noted, it doesn't seem to be the issue. Fill and it will run out the bottom hose. Disconnect the top hose and we get nothing.
    The only other difference is the intake. It is filling as far as I can determine. Coolant up to the thermostat neck and then coolant to the top of the heater hose opening (it's plugged off).
  16. treb11
    treb11
    My money is on a rag stuffed in a p***age left over from storage time
    Sent from my SM-G965U using The H.A.M.B. mobile app
  17. BJR
    BJR
    Show us some pictures of the front of the engine.
  18. wvenfield
    wvenfield
    No rags. We have had the front cover off. No rags. I pulled the engine out of a running car. We installed a new timing chain and cam but it was all ****oned right back up.
    We have the water pump off again. Will get it tomorrow if nothing gets figured out tonight.
    loudbang and Petejoe like this.
  19. buds56
    buds56
    Check the water inlet at the head. most of those old aftermarket pontiac intakes fit 55-64, and have two holes for the water. one hole is for the earlier engines and the other is for the 61-64 heads
    Make sure the port lines up with the water inlet in the headand the other is plugged. Had the same problem years ago with a 64 gto and a p22 edelbrock dual quad intake.
    loudbang and egads like this.
  20. wvenfield
    wvenfield
    THANKS!! I have to think it's something like this.
  21. wvenfield
    wvenfield
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Not sure if this helps or maybe you have spoken with Jeff Kauffman already.
    They helped us out on W/P issues on my Brother in laws non-Hamb ride.Very nice to speak with.
    They seem to know the Pontiac very well.
    Hope you get it solved.
    http://www.krepower.com
  23. wvenfield
    wvenfield
    I think buds56 had it. Pulling intake now. Ran a wire and it doesn't seem open.
    Doh.
  24. wvenfield
    wvenfield
    The intake was the issue. Thanks.
  25. bchctybob
    bchctybob
    Interesting problem, glad you found it. Please post some pictures of what you found.
  26. wvenfield
    wvenfield
    Aftermarket intake. Two holes. The earlier engines have water running through the rear hole. Newer through the front. I'm ***uming thats because of the reverse flow on earlier engines.
    This one had the plug in the front (since removed). Luckily we had a correct gasket as the rear is an oil p***age. IMG_20201209_132812292.jpg IMG_20201209_132823761.jpg
    loudbang, bchctybob, egads and 4 others like this.
  27. guthriesmith
    guthriesmith
    Glad you got it figured out!
    loudbang and wvenfield like this.
  28. wvenfield
    wvenfield
  29. Wrench97
    Wrench97
    Could that be because the early engines use the front of the heads to flow water from the pump?
  30. Mr48chev
    That is probably some of that "back when but no pretty well forgotten now knowledge. I worked in Pontiac dealerships in the 70's but didn't do engine work.
    A search shows that the same water pump fits all of the Pontiac V8 engines from 59 through 68. Evidently they made a change in 69. Or is that the "Late" pump mentioned above?
