Poor mans 18 inch divco wheels
Discussion in 'The Hokey Ass Message Board' started by mad-cad, Apr 19, 2006.
  1. mad-cad
    mad-cad
    Seeing as the unobtainable divcos are priced through the roof,I was looking for inexpensive 18 inch wheels for the Bonneville car and I found these rims they are 18x4.5 with a 5 on 4.5 bolt pattern and a 4.25 backspace,they are solid center stamped steel construction.these are new wheels and only cost $135 a piece.Poor mans Divco's I guess. Here's a pick of one .they are the space saver wheel for a Nissan Murano.
  2. McKee
    McKee
    I was parked next to a Nissan Murano the other day and I noticed it had 18" steel wheels with 235 tires,...thought it would look good with full Moon discs!
  3. that's an awesome idea man good find!
  4. Man that rocks. I might need some of those...:)
  5. KIRK!
    KIRK!
    New Dodge Rams have 20" steelies for spares!
  6. 34Fordtk
    34Fordtk
    But the Dodge wheel is 8" wide...but it could be narrowed some. Great find!!
  7. randydupree
    randydupree
    from archer fl
    can you get speed rated tires for the18'' wheels? i need some tall ones for my speedracer too!
    randy
  8. flatheadpete
    flatheadpete
    from Burton, MI
    I have a pair of 18" Astro van (5-5 pattern) with 6.50-18 Firestones on em for the Beater. Cost me $10 for both wheels at the junkyard. The Murano (which looks like ya gotta be a *****o to drive) is a good find!
  9. scootermcrad
    scootermcrad
    I would also like to know this... BTTT!
    kidcampbell71 likes this.
  10. sodas38
    sodas38
    S-10's have 16x4 space saver spares, look almost identical to that. Monte Carlo and similar have 15x4 inch wheels. These will take speed rated tires no problem. They also fit over disc brakes if you happen to use them up front.
  11. mad-cad
    mad-cad
    Dunlop racing tires make a few tall tires ,I have a pair of 7.00x18 tires they are 32 inches tall,the SCTA Bonneville people rate them to about 250mph although they must have the tread shaved down a bit on the edges.
    Here's a link to the people that sell them over here
    http://www.sascosports.com/products/specs.php?type_id=25
  12. hot rod pro
    hot rod pro
    from spring tx.
    dunlop has a 700-18 vintage racing tire that is rated to 149,but if you shave the tread down they are good for over 200.coker sells excelsior vintage racing tires that are rated at 149 also.it is also a 700-18.
    just be ready to open wide,speed rated tires are pricy.
    -danny
  13. scootermcrad
    scootermcrad
    WHOOW! You can say that again! $400 for that Dun! :eek: And you still have to buy another one! And if you're going to do that you might as well get the fronts too! :eek: Not a poor mans tire by any means! Would be awesome to have though...
    Mad-cad... what are you going to run on those $135 specials?
  14. I'm interested in this also. Do you know specifically who's running them , or where you heard this about 250 ? I don't mean to call you on what you said, I just want to talk to someone running them and that has run them up to 250, or however close, and how they arrived at that rating ? Before spending $1000.00+ on 2 tires & wheels to potentially have a life & death situation. I plan on my tank running 200+ by the end of the first meet.
  15. mad-cad
    mad-cad
    There are quite a few cars using the Dunlop's,Jim Tone uses them on his fuel roadster and has gone 200+,Jim is also an SCTA official. Then there is Car #811 which is also a fuel roadster,they have been 237mph on the dunlops.All the people I've talked to shave just about all the extra tread off the dunlops so they won't 'chunk' the treads.On the landracing.com website there is alot of discussion about tires and rated speed.Hope this helps
    Tim
  16. Too Cool!...now I just gotta remember this tip...Hmmm
  17. custom_lettering
    custom_lettering
    from Wall, NJ
    One thing to keep in mind is the backspacing is deep. I had 4" x 16" spare tire rims on a 35 ford that someone put a Pacer front end on and the 4" backspacing solved the wide problem perfectly. So my 4" wheels had 4" backspacing and that could be too deep for your application.
    Tim likes this.
  18. X38
    X38
    2006 thread, OP not seen since start of last year.;)
    lothiandon1940 likes this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
  20. jimmy six
    jimmy six
    18” space saver wheels have always been a go to for a vintage look. I believe Range Rovers were aluminum.. I’ve also used space savers for 16” Dunlops.
  21. Tim
    Tim
    from KCMO
    if a 49 up outer mount hubcap fits these they’d sure p*** at a glance that’s for sure
  22. alchemy
    alchemy
    I don’t see any hubcap nubs, but a guy might be able to add them.
    Tim and Moriarity like this.
  23. krylon32
    krylon32
    from Nebraska
    Probably don't take early Ford caps?
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    I bet they are cheap, maybe get one and see if you can make it take a Ford cap?
  25. Tim
    Tim
    from KCMO
    I’ve seen wheels like that with out Nubs on the inside get a little weld added for a bump to keep the cap on if that inner diameter works.
    or again if the inner diameter work you can still buy the rivet on tangs that Lincoln’s used in place of the bumps fords have. Ford caps will work with them still
    Squablow and Moriarity like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    heres a link to car-part.com inventory on these wheels in your area, starting at 38 bucks each. Maybe you can modify to accept a ford cap....
    https://www.car-part.com/cgi-bin/search.cgi
  27. The37Kid
    The37Kid
    Nice to see a 2006 thread arise to the Top again. :cool:
    Squablow likes this.
  28. Mr48chev
    Holiday boredom searching without checking the actual date (s) of the thread before you answer. It happens every major holiday.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    It is actually relevant again as @krylon32 hasn't been able to find wheels....
    Tim likes this.
  30. gimpyshotrods
    gimpyshotrods
    Old thread, but I would like to add something, which I feel is important, and doubly so if this is a LSR car.
    Quite a few space saver spare wheels only have a safety bead on one side. They often only have it on the outside lip, but not the inside lip.
    I know that this is not an issue for many, but I wanted to put it out there.
    The37Kid likes this.
